Just picked me Ute up from the dealer today 2004 TD42 ST with 150k on the clock. Shes got a Snorkel, Winch Bar, Winch, UHF, 3" Exhaust, Lightforce spotties, BFG All TerrainsIMG_0043.JPGIMG_0045.JPGIMG_0046.JPGIMG_0047.JPGIMG_0048.JPG
Nice looking ute mate, I would like a ute but it would need to be the right one.
Yeah I had a look at another one a couple of weeks ago which was a little be nicer and 2 years newer however the dealer wasn't prepared to negotiate on price. Was gone a few days later.
Need to get some Xlr8 steps for her and get some quotes on canopies, EGT Gauge, Turbo upgrade, brace for the coil towers, bigger lift
And the list goes on ........ Nice looking ute there Fish
Well I found out why the dealer wasn't locking the toolbox yesterday and have bent the key. Found the rubber seal to be fucked and thing was rusty as well.
Had some spare locking mechanisms that I had bought at one stage to build my own set of draws that just never happened. So out came the drill and removed the Pop rivets of the existing one. Had bought a pop rivet gun and a set of mixed pop rivets from Bunnings near work however the pop rivets were too small.
Off to bunnings to get the right sized ones. One didn't quite fit right so will have to drill that out and re-do.
My only pain point now is there is too much play when you pull on the handle when locked. Seems to be a huge spring washer on it compared to the other one i have here. Anyone know if I can just remove the pin and and take the nuts of and replace the washer?
You should be fine to remove the washer.
Although you can't just tighten the nuts so there is no slop in the spring part of the washer.
Great red ute
Bought a new head unit for the ute today which has bluetooth car kit built in. Also fitted up a flushmount usb and headphone jack. Will post up some pictures later
