Results 1 to 10 of 12
Thread: Portable fridge / freezer - Dual battery project
    Sep 2013
    Brisbane
    Hey,
    Looking at buying ourselves a 12V portable fridge / freezer.
    Knowing that Waeco is rather dear, and looking around have found a GIANT 100lt dual control fridge freezer - 2 separate compartments.
    Using a Danfoss compressor which comes with a staggering 5 yr warranty and only just over $1K.
    The next obvious project is dual battery. Would like to get Fridge out of the way so that I can then decide on battery size.
    Would be great to hear from anyone who has had experience with this brand or know of someone who has.
    Shane
    Patrol Freak gaddy's Avatar
    redlands
    No idea on that brand sorry , but since your in brisbane google getawaco , they are the factory seconds outlet , you might be surprised ,
  4. The Following User Says Thank You to gaddy For This Useful Post:
    Beucam (29th August 2014)
    Patrol Guru TimE's Avatar
    Canberra
    I would also be concerned about the amount of power a 100l fridge required to keep it going. People complain about the power consumption of 80l fridges.
    Western suburbs of Melbourne
    11 Post(s)
    Waeco do consume a little more power than an Engel, but Engel being dearer needs to be considered.
    For such a big fridge, perhaps a permanent solar panel, is a thought, but your already wanting cheaper products, so your in a pickle.
    Oct 2010
    Old Bar, NSW
    That's the problem, good gear costs good coin.
    Solar is a good suggestion with a decent charger / regulator it can do the dual battery control too, saves doubling up on pieces of kit to make it work properly.
    Macca
  8. The Following User Says Thank You to macca For This Useful Post:
    MEGOMONSTER (28th August 2014)
  9. #6
    Sep 2013
    Brisbane
    Quote Originally Posted by TimE View Post
    Looking at specs, 5Amp continous draw with total of 60W power.
    Waeco 65lt specs state 5.4Amp continous and 65W of power.
  10. #7
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by Beucam View Post
    That current draw does not seem correct for the Waeco 65, from memory it was under 1 amp continuous/average use
    EDIT: OK, I think the 5.4A is max draw (65/12=5.4)
    ________________________
    ______ 2017 D-Max _______
  11. The Following User Says Thank You to Maxhead For This Useful Post:
    BigRAWesty (29th August 2014)
  12. #8
    43 Post(s)
    Nisshead is correct your amp draw is low.
    Max is 5.4, I was surprised about this when I bought mine..
    You have to remember that's it's draw. You need to look at duty cycles for keeping a fridge at say 3 degrees..
    My 50l waeco runs around the 30% to keep my foods cold. Of course I'm in a slightly colder climate than most but a 100l fridge will have to run for much longer per hour to keep the foods cold...
    That is why you buy once buy right..
    The waeco has great insulation, inbuilt 240 inverter, great size.
    The unknown brands are unknown for a reason..
    If it was my $1000 I'd buy waeco again as it's a long term investment..
    And we did 2 weeks on the road with a 50.. You just pack smart..
    brisbane
    I wouldn't even look at Engels over 50 ltr they are twice the weight of Waeco and that's empty, but I agree on buying a quality fridge it's not worth loosing food in a remote area or killing batteries because its inefficient as constantly replacing these will be more expensive in the end. We have a 80 ltr fridge freezer and go 3 weeks with that easily, I think 100 ltrs is overkill but just my opinion.
  14. #10
    Expert Tonks's Avatar
    ACT
    Don't buy a cheap look a like, spend the coin and buy a good one,
    We have a 40 litre Engel & a 60 litre ARB, both are awesome fridges,
    The 40 litre Engel for the cold cans & the 60 litre ARB for the rest,
    Happy Days.
    2004 GU111 4.2 TURBO WAGON, 2" OME SUSPENSION, 33" MTZ's, 3" BEAUDESERT EXHAUST, ARB ROOF RACK, ARB AWNING, BLACK WIDOW DRAW SYSTEM & CARGO BARRIER, DUAL BATTERIES, 12,000lb WINCH, GME UHF, LIGHT FORCE XGT SPOTTIES, BERRIMA DIESEL TUNE.
