Results 1 to 10 of 12
Thread: 2001 4.5ltr patrol help
    Jun 2013
    Woodford
    hello guys and girls
    i need help. (in more ways than one lol)
    i need someone with a 4.5ltr to take a photo of where the engine coolant temp switch pluggs into please. i have tryed and tryed to find in manuals but with no luck, even had it to a mech and he said yep it should be conected but even he dosent know where.
    so please help
    49 Post(s)
    Try a Google image search. If I remember I'll take a shot of mine, if I can find it... You after the switch or the sensor.
    Jun 2013
    Woodford
    The sensor where the plug plugs into. The sensor that is in the bottom drivers side of radiator please
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I'm not sure what you're calling an 'engine coolant temp switch'. My 2001 4.5 auto has no temp sensors in the radiator itself.
    If you're referring to a wiring loom on the RH side with a grey 2 pin plug, it's for a 2nd electric fan in some markets. There's a place to plug the relay in just behind your battery.
    Perhaps you could put up a pic of what you think should be connected?
    John
    Jun 2013
    Woodford
    Hello here is a photo of what I mean. The one attached to fan housing is a sensor from under the radiator and I think it is ment to plug into the lose one but both male plugs
    Jun 2013
    Woodford
    Morayfield, QLD
    I have one of those plugs taped up behind the A/C receiver/dryer but not the one you have clipped onto the fan shroud.
    I took pics and can post tomorrow if you want to see..
    John
    Jun 2013
    Woodford
    Please jff45
  10. #9
    Morayfield, QLD
    Here's a pic of the plug on mine that is taped to the loom behind the A/C drier.
    I think it's pretty clear that it has never been in use.
    Pic showing nothing clipped to the fan shroud.
    As mentioned, I have no sensors in the radiator itself and it has never been replaced.
    Mine is a 2001 TI so it's auto trans.
    John
  11. #10
    Jul 2012
    I think those plugs are for the AC system pressure switches?
    The plugs for the coolant temp are both on the head near No1 cylinder - the two wire one is for the ECU, the single wire one is for the instrument panel gauge.
