31st July 2014, 07:55 PM
Steering wheel shimming between 80 to 100 KPH
Hi Guys,
Wondering if anyone some ideas on wheel shimming, i have replace pivots bearings and shims, wheel bearings done and re adjusted, steering box adjusted, steering damper replace, off set castors bushes fitted to lower control arms, tyres were re- balance and they tell me they were ok, all that has in proved it, i am out of ideas now!!! HELP!!
31st July 2014 07:55 PM
31st July 2014, 08:17 PM
Tell us what mods you have lift , tyre size etc
31st July 2014, 08:28 PM
Nasty Dog - Moderator
First thing to do is post up an introduction before asking for assistance, that gets everyone on side from the start mate
If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
Found this list of possibilties, may be of use
Wheel balance
Out of round tyres (as opposed to out of balance)
Loose wheel bearings
Insufficient castor
Worn or urethane panhard bushes
Worn drag link
Adjustment of steering box
Worn tie rod ends
Cracked panhard mount at chassis
Steering damper unserviceable
31st July 2014, 10:15 PM
Many 4WDs have this problem. The usual cause is tyre balance. Go to a tyre dealer that specialises in 4WD and truck tyres. Some of the balance machines are OK for passenger tyres but don't always work well on larger, wider and heavier tyres. If you can't find any in Wang - try Tower Tyres in Wodonga.
31st July 2014, 11:19 PM
Mines doing the same ATM from flogged out radius arm bushes (chassis end) but worn panhard bushes can give a similar feel in my experience.
1st August 2014, 09:50 AM
Every time I have shimmy it's a flogged or starting to flog tie rod end, I go through the motions of checking everything to make sure but it's always the rod end.
The pan hard bushes give a violent shaking when they go
1st August 2014, 05:33 PM
liftlid
Thanks guys for all your suggestions,
We own Y61 2006 TD42T with leaf springs, It has 265/75 R16, which had Coopers ST Maxs, but now running Toyo muds, has the standard 2inch lift, have done radius rod bushes, have done panard rod bushes too, i have taken couple times back to tyre power and they says balance was ok, i am think of going else where to see if they can help, i have check tie rod ends couple of times but can't get any movement out of them
1st August 2014, 05:37 PM
I replaced front wheel bearings before this Cape trip and tightened them up just a fraction more than usual and they are perfect with no wobble at all.
1st August 2014, 05:39 PM
Try Swapping tyres ft to back see if it changed
