19th July 2014, 06:41 PM
Moderator
DIY CV and Swivel Hub Rebuild Thread
OK So one of the big maintenance items that we may attempt at home is a CV swap or Swivel Hub Rebuild. I have done this a Few times and have had these pics ready to go for ever!! I have referenced them a few times to members and thought it was time i actually did this thread so here it is!
A Comprehensive Swivel Hub Rebuild Thread (Hopefully)
So firstly THE MOST IMPORTANT Information!
In the pic above you have all the info you need to get the job done.
The numbers below each of the tightening points are read like this N-m. kg-m. ft-lb
i.e.Lock nut - 167 - 196 (17 - 20, 123 - 145) = 167-196Nm, 17-20kg-m, 123-145ft-lb
The Black Circle Dot with the white X indicated the item should be replaced every time the hub is stripped.
The Grease gun symbol indicates to pack the seal lip with the recommended grease.
I have always used Nulon Extreme grease for all my jobs but recently changed to LM grease for the bearings after we did Healys front end.
You will need a Heap of Rags. Lots of them. I also use paper towel as it can get really messy and you will waist a heap of rags.
You will need a clean place to work if you can and jack stands.
Tools will include:a
- 1/2" Metric socket set
- Metric Allen Keys
- Pointy Nose Pliers
- Vice Grips
- Multi grips
- Brass Drift or Cold Chistel
- Soft face Hammer
- Big Hammer
- Vice would be bloody handy!
Things i have purchased and rate very highly are the following:
- Lip seal remover
- Seal/Bearing Insert Kit
- Bearing grease press
I also recommend a couple of trays to lay stuff out in and somewhere to put all the bolts and nuts as you take it all off. Stay organised and you will do this easily.
Lip seal removal tool (less than $20)
MECHANICS-SEAL-PULLER-REMOVER-REMOVAL-HAND-TOOL
The Bearing Driver kit Less than $50 and Highly recommend one of these to everyone!!)
10PC-AUTO-BUSHING-font-b-BEARING-b-font-RACE-AND-SEAL-font-b-DRIVERS-b-font.jpgrt9139.jpg
Bearing-Race-and-Seal-Driver-Set-10-PCS-
Cant believe how handy these kits are!!
and the Ducks Guts!! The bearing Grease Packer!! HELL YEAH!!
There are a few different types that will do the same job. I love mine and it was about $50.
Search eBay HERE for Bearing Packer
Once you have used one of these you will Never go back!!
I have used the Terrain Tamer swivel hub rebuild kit a few times and am very happy with the quality of the kit.
As a rule i have always done the Swivel Hub rebuild, wheel bearings and King Pin bearings all at the same time. Doing this rebuild will transform how your front end feels and you will feel the difference through your steering wheel as soon as you drive.
Good Luck and dont hesitate to ask for help if you need it.
Let the Photo Bomb Begin!!!
Check out my Toy -->
Rogue Dung Beetle
The Following 26 Users Say Thank You to MudRunnerTD For This Useful Post:
89GQ (7th November 2014), balum (14th December 2014), Buzzo (28th January 2024), Conradk (31st October 2014), Cruiser28 (15th December 2016), Dbcf79 (6th July 2017), dom14 (21st September 2017), FNqGu04 (14th January 2017), growler2058 (20th July 2016), Hodge (27th September 2017), im2xtreem (24th July 2019), ISA.13B (31st December 2014), kedocrott (25th October 2015), LandRoverGhost (22nd July 2019), MB (14th June 2018), New2town (7th July 2017), NissanGQ4.2 (20th July 2014), oldbloke (25th July 2015), OuchOne (20th May 2022), Parksy (20th July 2014), PhysicalGraffiti (16th October 2014), porkroll (21st December 2014), seehuusen (18th July 2022), warthog1 (7th May 2018), Warwick89 (13th October 2014), Woof (20th July 2014)
19th July 2014 06:41 PM
19th July 2014, 08:00 PM
Moderator
The Following 6 Users Say Thank You to MudRunnerTD For This Useful Post:
Conradk (31st October 2014), dom14 (21st September 2017), graeme1969 (20th July 2014), NissanGQ4.2 (20th July 2014), Parksy (20th July 2014), Warwick89 (13th October 2014)
19th July 2014, 08:37 PM
Moderator
The Following 7 Users Say Thank You to MudRunnerTD For This Useful Post:
AB (19th July 2014), Conradk (31st October 2014), Danny Trotter (19th June 2021), graeme1969 (20th July 2014), NissanGQ4.2 (20th July 2014), Parksy (20th July 2014), Warwick89 (13th October 2014)
19th July 2014, 08:44 PM
Moderator
The Following 8 Users Say Thank You to MudRunnerTD For This Useful Post:
AB (19th July 2014), Conradk (31st October 2014), graeme1969 (20th July 2014), gxlhas (20th February 2015), NissanGQ4.2 (20th July 2014), Parksy (20th July 2014), Warwick89 (13th October 2014), Wine_maker (4th February 2018)
19th July 2014, 08:59 PM
Moderator
Rogue Dung Beetle
The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
AB (19th July 2014), Conradk (31st October 2014), Parksy (20th July 2014), Warwick89 (13th October 2014)
19th July 2014, 09:15 PM
Moderator
AB (19th July 2014), Conradk (31st October 2014), graeme1969 (20th July 2014), NissanGQ4.2 (20th July 2014), Parksy (20th July 2014), Warwick89 (13th October 2014), Wine_maker (4th February 2018)
19th July 2014, 09:21 PM
Moderator
Now for the Big Bearings!! The Wheel bearings on a Nissan are a fair size. but my Bearing grease press eats them up! Love this thing!!
Yep thats right!! Done and Dusted! Love it!
Rogue Dung Beetle
19th July 2014, 09:33 PM
#8
Moderator
Conradk (31st October 2014), graeme1969 (20th July 2014), NissanGQ4.2 (20th July 2014), Parksy (20th July 2014), Tanker (4th May 2015), Warwick89 (13th October 2014)
19th July 2014, 09:46 PM
#9
Moderator
19th July 2014, 09:57 PM
#10
Moderator
The Following 12 Users Say Thank You to MudRunnerTD For This Useful Post:
abeeke (18th October 2015), Col.T (7th December 2015), Conradk (31st October 2014), graeme1969 (20th July 2014), jman69 (27th September 2016), Kerrbox (27th May 2023), LandRoverGhost (19th July 2016), mudry85 (30th May 2020), Parksy (20th July 2014), Warwick89 (13th October 2014), Wine_maker (4th February 2018), Woodsta1704 (27th March 2015)
