Yea you don't want to torque the strings and have a dry fire as a result. Can you bend it up so it doubles as a string stopper also with a rubber end on it
I only use rifles. However I have seen the aftermath of a mate stand hunting in a tree above a big mob of goats with his bow. Some of the most efficient culling I have seen, they had no idea.
In any moment of decision, the best thing you can do is the right thing, the next best thing is the wrong thing, and the worst thing you can do is nothing.
would never know what hit them lol at the end just a big pile of goats ha ha
Ummmmm??? String stopper??
Also would it still operate with the keeper running up and down a bit
No worries .. Just bend it out for the string guide then back in to where the nocking string is with a soft rubber end on the rod and you will also need to put some serving on your string where it comes in contact with the string stop/suppressor. Makes a big difference to the sound of the bow .
Plenty of vids on youtube about bowstring serving also and a real heavy braided fishing line will work also.
Like this one but.. . It just depends on the bow also as when you draw back the 2 strings that are guided will move back and may go past the point of where your nocking string sits undrawn in this case you can make one that comes off the stabilizer hole. This is whAt I've had to do
