Results 11 to 20 of 21
Thread: gq fuel pump fuse help
    Thomastown, Melbourne
    6 Post(s)
    You have gas fitted then... the big one is your ecu and has a 10mm bolt that holds the plug in. . Once undone you can disconnect the plug and tip upside down to see if water has got to it.
    The other unit is for your gas system.
    Aug 2013
    I bought it for the body mainly but it has that much wiring shit under the bonnet it scares me ,im in the middle of fixing 3 electric doors 2 low beams 2 spot lights maybe fuelpump power mirrors .ive been on the computer for days.i didn't realise how different it is to my good old diesel model .I cant even find if a fuel pump runs a fuse . it couldn't even handle a little squirt under the bonnet .
  4. #13
    Aug 2013
    the big ones got 4 bolts thathold abig gold plate, the little ones just sitting there
  5. #14
    6 Post(s)
    Quote Originally Posted by td42shayne View Post
    Mate mine just got a wash today with no issues... water on the ecu is a real problem but cant say this is your problem.
    All you can do is go through process of illumination. ..
  6. #15
    Aug 2013
    so should I undo the 4 bolt big one, it looks so dry under there.i thought I could see a bit of smoke and smell it under the bonnet be fore it stopped.
  7. #16
    6 Post(s)
    Takes 5min.... and that is one thing you can cross off your list.
  8. #17
    Aug 2013
    aussie I took it off undid the bolt unplugged turned upside and its not wet .where do you reckon next
  9. #18
    There is only 4 or 6 screws holding the casing on the ECU, it's worth taking them off to have a look for any corrosion in the ECU. It will be very obvious and only another 5 mins.
  10. #19
    Aug 2013
    bugger I just put it back. the one I just done had a row of green plugs and one bolt that holds them all in,i got the right one I hope.thanks fellas
  11. #20
    Aug 2013
    all fixed cant b elieve it.on the drivers side next to battery theres a plate with 2 screws bolt head,inside theres a little black box thing looks like relay sorta,took little cover off two fuses in there .changed fuse and wella shes going.theres a sticker that says something like ign ac ,im a happy chapy thanks fellas
