Results 11 to 20 of 32
Thread: My Dual Battery Install
    Ballarat, Vic
    174 Post(s)
    Having consulted my ‘advisor’ further I am informed that your set up for winching should work fine Ova50. My concerns were unfounded. If however you did want a bit extra ‘oomph’ for extended winching scenarios, you could run a heavy cable between crank battery positive and the winch via an inline high amperage manual switch. A warning light could be incorporated to remind you to switch off after use.
    Cuppa
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    ova50 (11th November 2013)
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    Cuppa: I would be the last guy to attempt answering your original question about batteries & winching. I dont have any expertise on the subject.
    When I sussed out which battery to wire it to, there seems to be two schools of thought on the subject.
    Thanks.
    Was a CRD
  5. #13
    Maitland NSW
    Great write up and pics. Some real good ideas. Thank you
  6. The Following User Says Thank You to FrankW For This Useful Post:
  7. #14
    Beginner Wang's Avatar
    Dec 2013
    Campbeltown / naw
    Great write up just about to a similar thing. I'm a bit of a neat freak and like to keep everything looking factory looking
  8. #15
    Heres some more ideas for you, for power outlets and charging options
    USB are live all the time Fridge switch off Aux battery
  9. #16
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Quote Originally Posted by megatexture View Post
    Love the fuse box i Just put one of these in my camper and love it having the blown fuse indecator LEDs beats testing each one
    http://www.jaycar.com.au/productView.asp?ID=SZ2001
    That is a great bit of kit
    www.swat4x4.com
  10. #17
    Expert clubbyr8's Avatar
    Penrith, NSW
    3 Post(s)
    Awesome thread, do you recall what size hole is required for the voltmeter. I like it's position and thinking about doing a similar thing.....
  11. #18
    Nov 2011
    I don't have the measurements available at hand. (have them on another computer)
    I should be back in Sydney at the end of the week and will post the details of the meter when I get back.
    Was a CRD
  12. #19
    Penrith, NSW
    3 Post(s)
    Quote Originally Posted by ova50 View Post
    Thanks Daryl. Also is the conduit the split type or normal electrical type? I have plenty of white electrical conduit but can't seem to find any black for a reasonable price......
  13. #20
    brisbane
    That stuff looks like standard auto split tube you can get it cheap at sca or repco or possibly even ebay
