Page 22 of 57 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 565
Thread: Parksy's gq
  1. #211
    Adelaide
    Quote Originally Posted by Parksy View Post
    Return to centre steering damper.
    Well worth fitting?
    Thomastown, Melbourne
    6 Post(s)
    Not a fan at all of those dampeners ... I have used them and on the GQ/GU I dont think they suit . my 2 cents!!!
  4. #213
    Adelaide
    Any particular reason you're not keen on them?
  5. #214
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Not keen also. I don't like how it feels especially when driving around car parks and the extra force that's needed on the wheel. Running a regular damper now. Apparently the rtc damper can mask issues as well. I did find my left front tyre wore quicker when I had the damper on. Removed it, rotated the tyres and the tyre that's now fitted on the front LH side isn't showing excessive wear.
    IMO and should be taken with a grain of salt.
  6. #215
    Adelaide
    Thanks for the heads up.
    So much to learn...........
  7. #216
    Legendary Alitis007's Avatar
    15 Post(s)
    Finally remembered bout the tape and primer all the partnumbers are on this pic
    And this is the primer
  8. The Following User Says Thank You to Alitis007 For This Useful Post:
    Parksy (6th May 2014)
  9. #217
    Jan 2013
    Nowra NSW
    5 Post(s)
    Made a new door card out of 5mm Masonite and black loop pile carpet. Instead of using plastic clips I opted for screws with retainers instead. Not sure if I'm a fan of the silver screw heads, but either way, the door is solid as a rock now!
    Note, it's not completed in the pic. Was just to give you an idea.
  10. The Following 9 Users Say Thank You to Parksy For This Useful Post:
    AB (11th May 2014), Alitis007 (11th May 2014), BigRAWesty (11th May 2014), Clunk (11th May 2014), Family4x4 (11th May 2014), FNQGU (11th May 2014), healy (11th May 2014), MudRunnerTD (11th May 2014), NissanGQ4.2 (12th May 2014)
  11. #218
    6 Post(s)
    Fancy pants....!!!!!!!!!!!!!!!!!!!!
    Was looking at mine only yesterday thinking they are getting ratty !!
  12. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Parksy (11th May 2014)
  13. #219
    Jan 2013
    Nowra NSW
    5 Post(s)
    Time for an update then BA! Mine were pretty ratty. Most of the clips wouldnt stay in place and it just felt wobbly when closing the door from the inside. Not that hard either.
  14. #220
    43 Post(s)
    Bloody nice work mate.
    I name thi 'the black shadow'
    Keep it up mate. Very inspiring
  15. The Following User Says Thank You to BigRAWesty For This Useful Post:
