Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Installing a catch can
    Mar 2014
    Perth
    Need help gents
    Does anybody have a how to page with pics to install a provent catch can to my 3lt patrol crd 2013
    As I'm not sure and don't want to botch it up
    465 Post(s)
    Hopefully Hodge will spot this thread as he has recently done this to his CRD. Its not really hard to do. The hardest part is mounting the can. You also need to make adaptors for the 1inch ports on the can to 1/2inch (from the engine) and 5/8inch (to the intake). How you adapt it, there is many ways. I used 1inch O.D to 5/8inch O.D copper adaptors from my local plumbers store. The inside diameter of the 5/8 end is 1/2inch, so I simply cut a short 1inch length of 1/2 copper tube , flared it and glued it inside the 5/8 end so then I had a 1inch O.D to 1/2inch O.D adaptor for the hose from the engine.
    Hope this made sense. Kinda hard to explain.
    If you need to locate the hose you need to tap into. Look for a hose that runs from the top of your motor and back to the air intake hose.
    Battleready76 (27th March 2014)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Did you purchase the "Patrol kit" from Western Filters? If you did then it comes with everything you need. Installation is pretty easy, just follow the instructions. I can take some photos of mine on the weekend if need be.
    If it wasn't purchase from Western Filters just be carefully as there are some cheap knockoffs around that don't perform as well.
  6. The Following User Says Thank You to Yendor For This Useful Post:
  7. #4
    Mar 2014
    Perth
    Thanks a bunch I've seen the western filter kits so that's a no brainer I'll order one and set myself to task
    I'm rather excited at the thought of becoming one with my beast as it stands up until now I've Been purely a 2wheeled racing nutter but age is catching up on me so riding is all about the BBQ / beer after a hard days thrash not the win
  8. #5
    Patrol Freak kevin07's Avatar
    georges hall
    I mounted mine on the plate infront of the abs unit I got a flat piece of metal and made an extendable bracket drilled and used rivnuts to mount everything up.ps rivnut set on ebay is $63 at the moment and if your going to do a few things around the car not a bad investment.kev
    13 y62 the beast that burbles
  9. #6
    Aug 2010
    adelaide
    go to your local super cheep store and for about 30 bucks you can get all the parts
    western filters kit too expensive some one uaed a holden hose thathas flared ends that fit cant find the link but have a rummage through their racks
    [ATTACH=CONFIG]42445[/ATTACH
    this is what i did
    [ATTACH=CONFIG]42448[/ATTACH ]300_0089.JPG
    and this is how to run the drain hose
    OH LEATHER IS NICE
  10. The Following 3 Users Say Thank You to my third 256 For This Useful Post:
    Battleready76 (28th March 2014), Hodge (29th March 2014), Rickie3 (28th March 2014)
  11. #7
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Here's the pictures of mine. The fitting kit makes it look like nearly a factory fit.
  12. The Following User Says Thank You to Yendor For This Useful Post:
  13. #8
    In reference to the adaptors needed to fit a member here just recently used a
    late model falcon heater hose which is flared both ends so you'll have a perfect fit.
    Had a look but cant find the post with the flared heater hose
  14. #9
    175 Post(s)
    Just like Yendor. I used a fitting kit supplied by Western filters, including the drain hose and the finish was very nice.
    Expert HV2002's Avatar
    Jan 2014
    Camden South NSW
    I Plumbed up my system with Ford heater hoses as they have a flared end that fit the provent perfectly . Here is the link http://www.nissanpatrol.com.au/forum...ler-leak/page2
  16. The Following 4 Users Say Thank You to HV2002 For This Useful Post:
    Battleready76 (28th March 2014), Lemo79 (28th March 2014), Robo (8th November 2015), skiman (8th June 2015)
