Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Sub tank fuel transfer pump
    Hi all,
    I've got a 75L sub tank to go into the GQ here and I'm collecting the parts to do the install. I received the dual filler neck today and am wondering what sort of fuel pump you should use to transfer to main tank? I've got no idea, couldn't find anything on google. It's for diesel if that makes any difference. Any help would be great.
    Not 100% sure on the GQ but one of my GU's is aftermarket
    Any eleccy pump will do fine assuming you are wiring it in seperately and not using the Nissan Sub Tank Computer.
    If you use the Nissan Computer you need to find a pump with a similar resistance or use a load resistor in parallel otherwise the stupid computer faults out
    I can't remember the brand of the aftermarket jobbie on my Ute but it transfers at approx 1 litre a minute (LPM) and I had to put a 7 Ohm load resistor across it.
    The factory pumps are a bit quicker at 1.5 LPM but gob smackingly expensive when I got some prices.
    If you use an aftermarket switching setup remember that the majority of pumps use the fuel to cool themselves so don't let them run empty for too long.
    Thomastown, Melbourne
    6 Post(s)
    Set mine up last week and gave it a run on Sunday while driving over to Andys house......
    Just a low volume that takes 5 million years to pump over.. need to improve on the set up but motivation is not there!!
    Thanks ET. No computer on the GQ. Really that slow? I was hoping for something a bit quicker even if it's 2-3 L/min
    The tank I got is from a TB42 so has a fuel sender in it, my plan was to wire that to the fuel gauge and have a switch to show the two separate tanks and watch the sub tank go down as it is pumping so I can stop it when it's empty.
    Maybe even have a double throw switch for the fuel pump so it shows the sub tank on the gauge only while it's pumping, I'd rather that than have two gauges.
    How have you done your Johnny?
    Sent from my iPad using Motorculture mobile app
    6 Post(s)
    Hey just a thought... did you get the bent upper control arm???
    Nah so many people say you don't need it but so many say you do... apparently depends on how much flex you have... I don't have much.
    583 Post(s)
    I heard that too mate but I think you should get it done as it will hit.
    Hardcore healy's Avatar
    south east melbourne victoria
    With the one you have its not needed it has the gap on the tank so it dosnt hit
    IF ITS NOT BROKEN IT MUST BE A PATROL
  10. #9
    Quote Originally Posted by healy View Post
    I don't think so
  11. #10
    Cool bananas...
    If you haven't got a sub tank computer then it's easy peasy... any 12 Volt fuel pump will do.
