Results 11 to 20 of 26
Thread: Stainless steel trivett
    .......... TPC's Avatar
    63 Post(s)
    I will take one, the one I have now is a pain to clean.
  2. The Following User Says Thank You to TPC For This Useful Post:
    BigRAWesty (19th March 2014)
    Hi all I have the trivets back from the Laser cutter,
    if you get one all you need to do is place it on a slightly
    open vice and tap with a nail punch or similar, turn it over
    and bend tabs to 90 degrees with a pair of plyers, pretty easy if you are handy
    with tools, PM if interested.
    Material is 2mm x 304 stainless steel, easy to clean
    and IMO better than whats out there ATM.
    Feet are 10mm off the base and diameter is 200mm
    As you can see perfect for a foil liner
  5. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (26th March 2014)
  6. #13
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Camp oven newby here. Is the idea just to get the roast or whatever your cooking off the bottom of the oven so the hot air circulates around better?
  7. The Following User Says Thank You to sooty_10 For This Useful Post:
  8. #14
    43 Post(s)
    Quote Originally Posted by sooty_10 View Post
    Yep. Makes it a more even oven..
    as above helps with convection plus if you cook
    your roast in a foil tub it'll keep your camp oven cleaner
    and the heat more even, eliminating any "hot spots"
  10. #16
    Stops the bottom of your roast burning too.
  11. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    BigRAWesty (26th March 2014), threedogs (26th March 2014)
  12. #17
    Bendigo
    7 Post(s)
    All what I thought, Thanks guys. I think my camp oven might be a bit small for your trivet though TD, will have to get the tape out.
  13. The Following User Says Thank You to sooty_10 For This Useful Post:
    threedogs (10th April 2014)
  14. #18
    brisbane
    I use oven bags sometimes if I don't feel like doing any cleaning works a treat unless a bone rips the bag.
  15. #19
    Oven bags work a treat until as you say they break some how, stews are my pet hate with the camp oven.
    After a weekend away enter the threedogs well two now, then a light scrub and oil ready for next time.
    cant wait to try my new alloy 12" camp oven7
  16. #20
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by megatexture View Post
    Double bag your bone when you're going in rough.....
    Hello from Under Down Under!
  17. The Following User Says Thank You to taslucas For This Useful Post:
    Avo (28th March 2014)
