25th March 2014, 10:29 AM
3rd anf 4th gear
Hey.
Was driving the patrol the other day and i noticed that 3rd and 4th gear grinds abit and takes a extra push to get them into gear.
Syncros?
Oil?
Im hoping its not a rebuild.
The oil in it is about 12,000ks old?
My mate suggested putting a thicker oil in.
Any info would be great
25th March 2014 10:29 AM
25th March 2014, 12:38 PM
Oil type can make a difference. What oil did you put in last time? You must use a API GL4 oil in the patrol manual.
25th March 2014, 05:33 PM
Im trying to remember mate.
Whats the best oil to use? I will head out tomorrow and grab it. I do remember it needs 6.1ltrs
25th March 2014, 05:50 PM
I use a 75w-90 semi synthetic gear oil by hi-tech oils. As long as it's API GL4 then you should be fine either in a 75-90 or 80-90.
25th March 2014, 08:55 PM
Where can i get the hi tech oil from in western sydney
25th March 2014, 09:07 PM
I can only find API GL5 oils
25th March 2014, 09:56 PM
10th one down is the GL4
http://www.hi-tecoils.com.au/?page_id=764
And here are the details for the Sydney area.
http://www.hi-tecoils.com.au/?page_id=272
I went from castrol EPX80-90 which is a GL5 oil and noticed cooler box temps and smoother changes. The smoother changes didn't happen immediately but it's certainly nicer now after 10k than what it was.
26th March 2014, 09:40 AM
#8
Had a similar problem after buying second hand, took it back to dealer and they replaced synchro. No charge. All good now.
Trev
26th March 2014, 04:53 PM
#9
I got the oil. Direct from hi tec oils
