Results 11 to 20 of 30
Thread: Extremely loud air intake sound when boosting
    Mar 2014
    Hey guys, just an update...
    I just had to drive it home from work and pick up the little one, i drove with windows down, radio off etc... seems to sound more along the lines of an exhaust leak when in the cabin.
    Motor is too hot to check now so ill have a good suss in the morning. Hopefully nothing major!
    175 Post(s)
    Do those RD28's have an EGR system? Could also be that. Just a thought.
    Yeah mate they do but a lose dump pipe maybe be the culprit.
    Hodge (14th March 2014)
  6. #14
    Mar 2014
    Hi Guys,
    Think we solved it, i jumped under looking for the loose dump, but everything looked great so did all the intake. Everything was clean and tight. After scratching my head and
    maybe a few profanities, i saw this shiny thing bouncing around under the IC. Keep in mind i have never seen an IC with an electrical fan attached to it, let alone on with this many connectors/piping etc.. so my description of what i found is bad haha. There was a little right-angle valve/joiner piece thing floating with a bleed pipe still attached to it. I felt around the IC and eventually found a small hole up the back of it and this piece fitted right in, albeit still a little loose. I plugged it in, started up and gave some revs, no black hole yet. I took the beast for a spin and alas! no massive air sound. Ill have to find the correct way to put this plug/valve in so it doesn't pop out again.
    Thanks to everyone on their speedy replies and great suggestions, i really do appreciate it, especially being new to diesel, 4x4 and patrols.
    I'll keep updated if this permanently solves the issue.
  7. The Following 6 Users Say Thank You to dodgypatrol For This Useful Post:
    Avo (15th March 2014), Hodge (15th March 2014), P4trol (16th March 2014), Stropp (15th March 2014), threedogs (15th March 2014), TPC (15th March 2014)
  8. #15
    175 Post(s)
    Great to hear you've solved it mate and even better the fact that it isn't anything more sinister. Easy loose connection or connection is always the best outcome!
  9. The Following User Says Thank You to Hodge For This Useful Post:
    dodgypatrol (16th March 2014)
  10. #16
    Phew! Good find. Stumped at what this thing is you found though...
  11. #17
    43 Post(s)
    X2. Could you post a pic of said culprit??
  12. The Following User Says Thank You to BigRAWesty For This Useful Post:
  13. #18
    Mar 2014
    @mudski; Yeah i think it's just a vac line? it doesn't seem to do much but runs back to some of of stock looking boost controller/bleeder thing with 3 knobs and heaps of lines coming off it.
    I have never seen one of these either.
    @westy's; I will post a pic of the thing sometime today.
  14. The Following User Says Thank You to dodgypatrol For This Useful Post:
    BigRAWesty (16th March 2014)
  15. #19
    Mar 2014
    Quote Originally Posted by Westy's Accessories View Post
    Here is the culprit. It slides into that hole on the back of the IC fairly easily so i'm assuming a seal of some-sort was destroyed in the process of the r'n'r
    I traced it back and i connects to about 5 different pieces that eventually ends up on the turbo's actuator. Now that it's in though car runs fantastic.Attachment 41944
  16. #20
    IC could do with a tub lol
    is that your boost hose that goes to your gauge?
