Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 80
Thread: Multimeters and test equipment.
  1. #21
    80 Post(s)
    Today I checked my battery charger/ 18 amp booster output with four meters connected.
    The inbuilt voltmeter indicated (MC) 14.9.
    My Kingdom ETU multimeter (MC) 15v.
    My Optilux (Auto specific) Multimeter (MC), 13.8
    El-cheapo E06100 digital multimeter 13.11 volts.
    Getting accurate base readings is going to be a problem.
    80 Post(s)
    My "toy" oscilloscope turned up today. It has slightly different characteristics to the online instruction manuals,and the interpretations from Chinese don't quite match either, but I'm slowly working it out. It has data saving and uploading to PC capabilities and a test output signal somewhere as well. I checked out a few different outputs from phone chargers and DC power supplies and got good results. If you listen closely you will hear me banging my head and tearing out my hair as I learn to use this nifty little device. Speedo sender signal output pics to follow...hopefully.
  4. #23
    .......... TPC's Avatar
    63 Post(s)
    That is a hell of a variation.
  5. #24
    80 Post(s)
    The Jaycar multimeter has turned up at the shop. Can't wait to get into town and pick it up. It will be interesting to see what it reads too.
  6. #25
    If you see something you want in the states and they don't post to Aust.
    Try gateway.com .they will supply an American address and resend it to you for a very small fee.
    OD put me onto them
  7. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    megatexture (14th April 2014), mudnut (15th March 2014)
  8. #26
    80 Post(s)
    The Jaycar QM1551 is shaping up to be a very handy piece of gear. It even has an inbuilt, non contact AC voltage detector light and a temp sensor.
  9. #27
    63 Post(s)
    Have you compared the DC voltage reading to the others yet?
  10. #28
    Doesn;t suprise me too much... 'cept maybe the last reading.
    Not many battery chargers output true DC so the waveform could be noisy as hell even across a Battery which is in effect a dirty great big filter capacitor.
    A difference of maybe a quarter volt would not be unusual on reasonable meters (not high end like Fluke etc) and throw in some elcheapo's and they variations could be way more
  11. #29
    80 Post(s)
    This is the AC output of the speedo sender at about 57kmh which shows around 174 to 178 Hz. (But I may have read that wrong)
    I am still learning the scale and accuracy of the screen.
  12. #30
    NT
    Here's a similar looking one I found tonight.
    http://www.adafruit.com/products/468
  13. The Following User Says Thank You to P4trol For This Useful Post:
