Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: New Quote Re Lockers
    Expert Gary Vansleve's Avatar
    Sep 2013
    Brisbane
    Just a follow up on quotes regarding lockers for the ute. as stated in post with title of Detroit marched off today to get a formalised quote from ARB to supply and fit lockers to front and rear of the ute.
    First up I have to fess up to a blue on the price quoted from ARB when originally advising the forum. The price I originally first advised was $4304 but when in fact it should have been $4183.00.
    Well anyway the formal quote now reads $3794.00. Also in addition they upgraded the compressor to a medium one (their words) so I can pump up tyres. They also added the pump up kit (once again their words) a tyres deflator PSI guage, a tyre inflator with guage and a speedy seal puncture repair kit. They also fit an supply new carrier bearings front an rear but no pinion bearings. Funny thing TJM and Opposite Lock do the same thing no pinion bearings huh
    Apparently this is some sort of promotional deal to flog off their lockers. The sales dude said I was lucky to show up when I did bla bla bla.
    So now this is the lowest quote an in addition I can also have a compressor to inflate tyres which I currently don't have.
    Now to the thing I hate most deciding on which lockers would have to be the worlds worst procrastinator. In my humble opinion my only fault gee what a tosser.
    [/SIGPIC]The old girl like me well past the use by date
    Patrol God Stropp's Avatar
    31 Post(s)
    Yeh the arb sound tempting but the Eatons can be wire twisted back together the air lines can't. Good luck with your decision.
    Expert gec's Avatar
    Geraldton WA
    Yep, but you can buy an airline repair kit to chuck in the tool box.
    Western Patrol Club member
    GQ with 5.7 Gen 111 V8, Dual ARB airlockers, 33" Coopers, 9000lb Premier winch, Black Widow draws
    43 Post(s)
    Walk in and them tell they have your cash, if they put the large compressor in...
    See what they say..
    have you been to TJM for a quote on a set of Pro-Lockers,
    Im sure it would be cheaper than $4300 and a better locker IMO
    Sep 2013
    Brisbane
    Yep TJM came in at $3946.07.
    At the end of the day I don't think you could go wrong pickin any of them as long as the outfit you pick does a good installation of their product. Must admit I am a bit perturb as to why none of them do the pinion bearings as part of the fit.
    Quote Originally Posted by Gary Vansleve View Post
    It's cos it's easier for them. If they did the pinion bearing then the centre would prob have to go to a diff specialist to get the backlash and contact pattern set up correctly. They just mark everything before the pull it apart put new bearings in and realign said marks. Its kinda guessing but works ok. If you were really unsure then purchasing the lockers by themselves and getting a diff shop to change all bearings at the same time wouldn't be a bad idea
  9. The Following User Says Thank You to nissannewby For This Useful Post:
    threedogs (6th March 2014)
  10. #8
    Its nothing to carry a length of 6mm Teflon tubing, its all just push fit fittings these days not so much an olive set up of old
  11. #9
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    who ever supplies FREE beer with the fitting would be the winna for me
  12. #10
    Sep 2013
    Brisbane
    I had a sneaky suspicion this may be the case I wonder if getting a diff shop to fit up would affect the warranty offered by ARB. All three locker mobs were very hazy when I brought this up. Admittedly I was only talkin to the sales reps of the stores.
    Seems a dick way of doin the install what if the pinion bearins were on their way out. If they fail after install where do you go keepin the warranty issues in mind. Fruck me
