4th March 2014, 08:27 PM
thanks for reply Yendor, mate I wire it all back up to the way I had it originally, I didnt like the idea of no remote locking LOL, I just locked drivers door manually
ust connected your new actuator parallel to the genuine actuators.
So connect the two wires from your new actuator to the Blue wire and Blue with a Red trace wire.
Ok will give that a try thanks, so clicking remote button sends a pulse through those wires to activate lock/unlock? hopefully it works, will report back tomorrow
4th March 2014 08:27 PM
4th March 2014, 09:17 PM
Rickie3
Sort of ..... When you push the remote button the alarm unit sends a negative trigger down one of the two wires you connected to the factory door lock/unlock switch in the driver side door master switch (the switch near the electric window switches).
This then activates the original central locking module. This module sends power to either the Blue wire or the Blue with a Red trace wire and earth to the other wire (it depends if it's locking or unlocking).
This is how you had it wired first off when all doors worked except for the driver side door.
Connecting your new actuator to the Blue and Blue with a Red trace is just the same as adding another rear door actuator. The factory central locking module it operating all the door actuators, the alarm system is just sending the signal to lock or unlock to the factory central locking module.
4th March 2014, 09:32 PM
ahhhhh ok now that makes sense, excellent info cheers, will let you know how I get on
5th March 2014, 09:02 PM
