Results 1 to 7 of 7
Thread: 2001 Nissan patrol y61 zd30 to td42
    Feb 2014
    brunei darussalam
    Hello guys..im planning on converting mu zd30 to td42..the question is..should i change the pinion gear as well to match the engine manual transmission?what else should i change?
    have a search there should be heaps of conversion threads for you to read.
    Top RH corner should be your starting point, good luck
  4. The Following User Says Thank You to threedogs For This Useful Post:
    seekers282 (1st March 2014)
    Feb 2014
    brunei darussalam
    Great..thanks threedogs..
    I dont think you need to. I think. I did read somewhere that the ratio of the zd30's is preferred? ?? Im sure someone will be able to shed some light. I will be leaving mine when I eventually do the conversion. Unless its screamong its guts out I will worry about it then.
  8. #5
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    All depends on what's in there and what tyre size your running? 4.2td generally come with a 3.9 or 4.1 diff. I converted a 2.8td to 4.2td and had the 4.6 diffs with 33's and found it to rev way to much for my liking on the highway so went back to the 4.1 diffs from the donor ute. 4.3 would probably be my preferred with the 33's or even 35's.
  9. The Following User Says Thank You to sooty_10 For This Useful Post:
    seekers282 (2nd March 2014)
  10. #6
    Feb 2014
    brunei darussalam
    Well..im using 285/75/16 right now with 4" lift..it look smaller when fitted to 4" lift..lol..maybe 315/75/16 looks bigger..but im afraid my zd30 engine would stress out ImageUploadedByMotorculture1393728096.209066.jpg
  11. #7
    Expert janderson's Avatar
    Bearii Vic
    3 Post(s)
    Mine is an ex zd30 converted to a TD4.2t. 2" lift with 33's. still running ZD30 ratios, no problems. Speedo is out, about 95Kmh is in fact 100Kmh. Revs show 2000rpm at 100Kmph, should be about 2500rpm's.
    1st G60 Then MQ Now GU
  12. The Following 2 Users Say Thank You to janderson For This Useful Post:
    mudski (2nd March 2014), seekers282 (2nd March 2014)
