17th February 2014, 09:16 PM
#11
tiny
470uf caps x 6 parallel is plenty.. Cost you less than 10 bucks from jaycar..
Awesome thanks! Do I put this on the 12V or the 24V side?
17th February 2014 09:16 PM
18th February 2014, 01:00 AM
#12
On the main current draw lead on your stereo. 12 volt side...
The Following User Says Thank You to tiny For This Useful Post:
chrisc2306 (18th February 2014)
18th February 2014, 08:04 PM
#13
Hi guys had another crack at it tonight before i ordered the capacitors and it was a success. I wired it direct to the battery giving out the 24v to ground so as not to drain one individual battery and the connected a 15A fuse in series with the 24v input before putting it through the convertor and everything worked as it should! Thanks everyone for their time and advice
21st February 2014, 04:16 PM
#14
I suspect the 24 volt supply was dropping with a load.
21st February 2014, 05:40 PM
#15
Check for a bad connection somewhere. A resistive joint will drop a lot of voltage under load
