Results 1 to 10 of 13
Thread: Zd30 auto to td42t auto conversion
    Beginner Coastalpatrol's Avatar
    Jul 2013
    Hi all
    I'm new to the forum, and I've just had my zd30 bomb it's self! So I'm sourcing the info and parts for td42t conversion! I'm going to retain the auto box. Also I will be upgrading to a larger turbo and top mount intercooler, my aim is for around 150kw? I'm thinking of a jap import td42t from gu with low ks! Has any body heard much about the import motor are they any good? Also can somebody recommend a turbo set that could achieve 150kw and at what boost I would need to run to reach that power? Does anybody have the link to the thread for a zd30 to td42t conversion? By the way great forum, so much info and so many patrol enthusiast out there too! Many thanks if anybody could be of help
    North brissy
    There is a member on here who has used the ZD30 auto with a TD42, "pattywagon" I think his username is. Also patrolapart have also done it and should be able to help you out. You might get away with the ZD T/C and flex plate as I know they use the same Clutch in the manual version, that's only a might.
    There a plenty of combinations to get to your goal. A good option would be a UFI 16g Large or a Garrett GTX2863. You will need a 11mm pump at a minimum and a good quality intercooler setup.
    Jul 2013
    How reliable are the td42t putting out 150kw? Considering you have a good intercooler setup and three inch exhaust! The jap import motor I was looking at was from Brisbane imports, low ks apparently under 100,000?? They said everything to do engine conversion was included $7900? Engine out of gu from Japan? Does that mean they are 24 volt? Would I only need to swap to 12volt alternator? Has anybody used a jap import motor? Also how hard to transfer to a manual, does it all swap over pretty easy? Thanks for any help
    Properly tuned a 150kw (at the flywheel) TD42t will still be extremely reliable, factory turbo TD42 has stronger internals than naturally aspirated so is well up to the task.
    As far as I'm aware all Safari's (what the Japs call Patrols) are 24 volt. As long as the engine has a straight mechanical injector pump (factory intercooled TD42Ti had electronically controlled injector pump) you should only need to replace the fuel cut solenoid with a 12 volt unit.
    Converting your vehicle to manual can be done using factory parts but there is a bit of work involved, pedal box needs to be changed, clutch master cylinder, and hydraulic line, and booster fitted, bolt in floor panel around gear levers changed, console trim changed etc.
    Patrol Guru paulyg's Avatar
    Ballarat
    Wholesale Automatics does a conversion kit for TD42 to automatic.
    Expert PattyWgnOwen's Avatar
    Jun 2011
    Brisbane North
    ive done it with only minor glitches around the actions of teh throttle position sensors and so on.
    the td42 will bolt straight up .
    pm me for details
    GU4_3"lift_4"exhaust_sliders_Bars_fridge_roof top camper_lockers_duramax_allison_ohh yeah!!!
  8. The Following User Says Thank You to PattyWgnOwen For This Useful Post:
    Sullyboix (16th June 2019)
  9. #7
    Jun 2011
    Brisbane North
    I did a full build up thread on the other patrol forum fir anyone interested.
  10. The Following User Says Thank You to PattyWgnOwen For This Useful Post:
  11. #8
    43 Post(s)
    Quote Originally Posted by PattyWgnOwen View Post
    Copy and paste mate. Heaps of interested members here..
    Jun 2011
    Brisbane North
    Sorry guys.
    I'm not going to maintain two threads with the same info?
    Makes more sense to keep everything in one place.
    And I don't get over here as often.
  13. #10
    Devon United Kingdom
    Hi I am a UK owner of a 2007 ZD30 'grenade' and have recently acquired a Jap import Safari with the TD42T unit (140000 km). Am considering switching the TD42T into the Patrol. Can you send me a link to the other forum for details.
