Results 1 to 4 of 4
Thread: Toddies Testing Thread 1
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Nissan Fast Installation
    These instructions should hopefully get the Nissan Fast System up and running for you.
    There are a few steps to installing Nissan Fast, I will do my best to explain, sorry if i get you completely lost, but that's what i get paid 2 do
    Step 1 - Program Installation
    1. In
    Windows Explorer or My Computer locate the AR.zip file you downloaded and extract the file to a Temp location. For this example i will use:
    C:\Temp\
    2. After the file has been extracted locate this directory
    C:\TEMP\AR\FASTPRG\WIN2000\SETUP
    3. Execute the Setup.EXE file
    4. You will be prompted to choose a destination folder
    I will leave this as the default C:\Nissan
    Select Next
    5. You will then be prompted to Start Installation
    Select Next
    6. It will then install, when the Install completes it will come back a prompt “Installation Complete”
    Select Finish
    Step 2 - Check That The Installation Worked
    1. There will now be a short cut placed some where on the windows task-bar, called Nissan Menu
    2. Select the short cut
    Nissan Menu
    This will open the Nissan Fast Menu
    Attachment 1706
    3. Select any of the icons in the menu, it should come up with an
    Error Message
    Attachment 1707
    4. Select
    OK
    5. Select
    Quit
    Step 3 – Copy the Nissan Fast Catalogs
    1. In Windows Explorer or My Computer locate the C:\TEMP\AR directory.
    2. Copy the AR Folder to C:\NISSAN
    Step 4 – Setting The CD ROM Setup
    1. In Windows Explorer or My Computer locate the C:\Nissan directory
    2. Locate the file NFSET.EXE and Execute
    This will bring up the FastSet Nissan Fast for Windows NFSET menu
    Attachment 1708
    3. Select the CD-ROM SETUP TAB
    4. Make sure Drive 1 is highlighted and select Browse, this will open the Browse For Folder window
    5. Locate the C:\Nissan\AR folder and single left mouse click on it
    6. Select OK
    Drive1 should now look like this
    Attachment 1711
    4. Select OK
    Step 5 - Run Nissan Fast
    1. Select the short cut Nissan Menu on the Windows Task Bar
    2. If it asks you to run a file called NFUdate.exe select YES, it will then go through an install procedure before opening the Nissan Fast Menu
    3. Select the Fast System Icon
    This will open the Main Nissan Fast Window
    If you have
    AR 1 showing then you have the Australian Catalog working, now you can sit back and have a few
    Attachment 1712
    *NOTE - Known Issues *
    1. If you run the E-Fast System and get a
    tdbg6.ocx error - you will need to download this file into the C:\Nissan Directory
    2. If running a 64bit operation system, you will have to run it in XP Compatibility mode for E-Fast to work or you will still get a tdbg6.ocx error
    Aug 2010
    17 Post(s)
    Merging post from one thread 2 another
    Merging this post into Testing Thread 1
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    POWER TRIP!!!!!! Hahahaha
    tappa slappn about
    Hello from Under Down Under!
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    61 Post(s)
    Go for it Todd mate, great idea.
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
