Page 1 of 9 123 ... LastLast
Results 1 to 10 of 82
Thread: Group Buy, 63% transfer reduction for GQ/GU
    Dec 2012
    Yatala, halfway between brisbane and GC
    approved by Andy
    ITEM: 63% transfer reduction gears for GQ and GU patrol
    PRICE AND PRICE CONDITIONS: $1300 + post. Yes thats cheaper than marks sell their kits for, and its a new custom run.
    CONDITION: Brand spanking new
    REASON FOR SELLING: I wanted a set for myself and the only way of getting them made is in a group buy of 15 sets.
    EXTRA INFO: Hi guys, for a long time I have been thinking about reduction gears for my GQ, especially after wheeling with some mates with cruiser utes and the much lower gearing they have.
    I did the maths, and a 43% reduction brings the gearing only just lower than a standard cruiser, but the other available option of 85% by marks 4wd is a huge step down and will result in much stopping and transfer leaving tossing.
    So I contacted Marks about making something in the 60-65% area, after reading a thread on here about that. After a bit of to-ing and fro-ing they decided they can make a 63% ratio and sell it as a kit exactly the same as their other kits, as seen here: http://www.marks4wd.com/mfk1515-2-86l.html
    Kit contains:
    · Input gear
    · Idler gear
    · Output gear
    · Bearing spacer
    · Welsh plug
    · Backlash eliminator
    · Instructions
    All GQ and GU vehicles run the same gearing in the transfer case. We haven’t confirmed this with the 2012 and onwards vehicles that were fitted with traction control.
    As some people may be aware, its commonly reported you have to die grind a small amount inside the casing to fit the 85% gears, according to marks this can be the case with the 43% as well, and the 63% will also fall into this category that some people depending on the casting will have to die grind a small amount inside the casing to maintain clearance.
    the ratio according to Marks is about 3.29:1
    I should mention, this is at the moment an expression of interest, I need to get enough interest to make this work, Please do not say you will buy if you are not going to come through, once I feel there is enough interest I will collect deposits and place the order with Marks 4wd. If it all falls apart after I start taking deposits I will of course fully refund any deposit taken.
    CONTACT: PM, reply, or Andy on 0433 108 569
    PICTURES: much the same as seen here:
    Interested parties:
    1. Love ke70 (Andy)
    2. Thrasher
    3. Patrol 28
    4. The Great 2.8
    5. Komodo
    6. Leck48
    7. FlexGQ
    8. Razor2000
    9. 89gqpatrol4x4
    10. GUTROL4.2
    11. chubba
    12. Pat (chubba's brother)
    13. MadK1w1
    14. 03gallagherj
    15. 2.8_hki
    16. UNKO
    17. s1mon
    If your name is on this list and you feel you will not actually come through with the deposit and payment when it comes that time, please ask me to remove your name from the list. This is much preferable to people not making payments at the end and letting everyone down.
    Cheers, Andy
  2. The Following User Says Thank You to love ke70 For This Useful Post:
    Drewboyaus (17th December 2013)
    583 Post(s)
    Yes, in case anyone is wondering Andy did ask me if this was ok first as he is trying to get the group buy on another forum as well and needs the numbers.
    I do not know Andy, nor am I involved with this group buy but good luck with it mate.
  5. The Following 2 Users Say Thank You to AB For This Useful Post:
    love ke70 (16th December 2013), PMC (16th December 2013)
  6. #3
    This will be the 3rd one I have seen it on lol.
  7. The Following User Says Thank You to nissannewby For This Useful Post:
  8. #4
    Dec 2012
    Thanks AB
    Nissannewby, yeah here, outers (which has had 0 response ) and patrol4x4 (who are eatin it up)
    Alot of people dont frequent all forums, so you gotta spread the love you know...
    Cheers, Andy
    97 patrol coilcab ute. 4" lift, snorkel, 315/75R16 cooper S/T's. and about 200rwhp and some expensive bits and pieces
    Organising a group buy for 63% transfer reduction gears, check the link here
  9. The Following User Says Thank You to love ke70 For This Useful Post:
  10. #5
    22 Post(s)
    I would consider it. I already have the 85%, If I could offload them I will jump on these. I'll keep my eye on the other forums (i have an account on all three) as well if you get stuck on the last 1 or 2 let me know
    96 GQ coil/Cab
    08 G6eT
  11. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  12. #6
    Thomastown, Melbourne
    6 Post(s)
    Slut!!!!!!!
  13. The Following 3 Users Say Thank You to Bloodyaussie For This Useful Post:
    Ben-e-boy (16th December 2013), PMC (16th December 2013), rusty_nail (17th February 2014)
  14. #7
    Dec 2012
    No worries Ben, whats your issue with the 85%? too slow for most stuff?
  15. #8
    22 Post(s)
    Quote Originally Posted by love ke70 View Post
    I usually play in the rocks and ruts and the 85's are everything I want for crawling. Typical SE Qld terrain.
    In october I went down to the high country and the distance between obsticles is pretty far. Not like little red to big red.
    Most of the steep terain is too steep for 4H and annoyingly slow for 4L
    I really like crawlin and the 43% are more suited to a tourer, the 63% I think will be the right combo for a crawler that might tour aswell
    96 GQ coil/Cab
    08 G6eT
  16. #9
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Hi Andy .Have been agonising over the choice between 43s and 85s, the 63s may be the answer. What sort of time frame are we looking at?
  17. #10
    Dec 2012
    Thanks for that Ben, that was pretty much what I was thinking when I approached Marks for the gears
    Chubba, I will start taking deposits as soon as I have the 15 so it does not get too long winded, but if it happens before christmas new year I would probably wait til mid to late Jan for everyone to get on board before putting through the order and then its 6 to 8 week wait for production, which is when the final payment would be needed.
    Cheers, Andy
