Some fantastic entries coming in thick & fast. Great to see.
Don’t forget that if you don’t have any suitable entries yet, you have a whole month to get out & about in your Patrol to take some pics. Maybe try experimenting with your favourite watery location at different times of the day, or even staying home & seeing the difference that different lighting conditions make on that garden spray. The possibilities are endless. Don’t forget that everyone gets a chance to vote so voting criteria is personal. Some will go for the technically good shots, others will go for content ...... so you don’t need a fancy camera. Give it a shot, the more the merrier.
Cuppa
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
