27th November 2013, 07:21 AM
#21
Jimbo65
Before new rubber ( Yoki Geos A/T-S) & fr whl brgs there were no issues, but since...well fair to say it's p*ssed me off no end. Wobble felt thru & visible on strg whl only. Speaking to my old man who has owned early landy's & Jeeps reckons to remove a shim from the swivel hubs thus altering the pre load on the brgs?? All comments thus far received have all been in good gesture for which I am thankful but what has got me stuffed is why why has all this started since getting new rubber & whl brgs....something has obviously changed in the set up/dynamics. The joys huh. Will let you know once RTS damper is fitted.
changing rims front to back can cause issues if they are buckled
07 crd,,bridgestone 697lt, 2.75 buedesert ex,
SOLD theres a lot of my blood, sweat and money in that troll.
92 gq ti tb42efi my brothers gq extractors dual batteries brake controller uhf alloy bullbar
SOLD with a heavy heart but gone to a nice young fella
13 y62 the beast that burbles
27th November 2013 07:21 AM
27th November 2013, 04:59 PM
#22
Hey Westy, no bushes have been changed as yet....bushes on fr suspension are Nolathane & seem relatively new but who knows. Rubber I was referring to was tyres. Will let you know about RTS as it arrived this morning so will bite the bullet & fit it. Landcruiser Park this w/end so we'll see what happens.
27th November 2013, 05:18 PM
#23
I have read somewhere that rims with a deeper offset can help control the wobbles by putting a bit more pressure on the swivel bearings. Someone please correct me if I am wrong.
30th November 2013, 10:32 PM
#24
Ok I have had the wheels balanced and thought it was fixed but today out of the blue she wobbled like hell again at about 70kmh the place that did my swivel hub bearings said they didn't have to use shims in swivel hub caps is this normal?? I'm really starting to get annoyed now as I'm not sure what to do now and yes it has rtc dampner on it and I've spent lots of coin replacing everything surely someone can help me solve this cheers
Gq patrol lwb 4.2diesel running gt3076 top mount intercooled (with fan) 15psi 4inch springs 2inch body lift slowly adding bits as I go love it
30th November 2013, 10:36 PM
#25
Also my rims are huge offset neg 44 I've been told but it shouldn't have anything to do with it because they have been on there from day 1 with no trouble
30th November 2013, 10:40 PM
#26
If you have not replaced bushes I'd start with both panhard rods.
Nolothane have some not so good reports of prem wear.
Genuine bushes are the go.
You say the hub bearings got done, what about wheel bearings??
If not then try tightening them a little..
30th November 2013, 10:58 PM
#27
It has brand new toughdog panhards all bearings were done swivel and wheel bearings a week and a half ago
30th November 2013, 11:00 PM
#28
Also as I said it has a new adjustable drag link wheel alignment just done I'm running outa things to do:/ anymore ideas??? I'm at a loss
1st December 2013, 03:06 AM
#29
Smart like tractor
Gq turbo
Gq turbo
Not having shims in the swivel hub bearings will put more preload on the bearing, so it is less likely to cause this.
I used to run rims with -44, I also put more preload on the wheel bearings to keep the wobbles in check, the downside is the more preload, more heat, shorter bearing lifespan. But there is a fair bit of extra weight the wheel bearing has to endure
Replacing bushes has been mentioned many times.
There is a big difference between bushes that "seem" ok and bushes that are ok. The crush tube in Nolathane bushes will pull away from the bush and it will slop around in there. Flex it up and see if the crush tube is pulling away from the bush
96 GQ coil/Cab
08 G6eT
1st December 2013, 07:09 AM
#30
As a last resort throw some balance beads into the tyre,
but first I'd be jacking a front wheel off the ground and making sure bearings are tight.
Can you try with another rim/tyre combo??
