Results 11 to 20 of 28
Thread: EGR stuff
    465 Post(s)
    Quote Originally Posted by Rumcajs View Post
    I'd put catch can higher up on the list not the last. I'd also not bother with Dawes valve without doing needle valve at the same time, you gotta take turbo control away from ECU.
    Intercooler is probably cracked already and leaking, any dark patches spreading about the fins near the end tanks? Don't forget that glow plugs timer mod should be high on the list too.
    The ridiculous post glow time Nissan has set (5 mins) leads to all sort of problems.
    I only put the catch can last on the list because of importance really. I really doesn't matter when you do the catch can. I couldn't agree more about the dawes and needle valve, but you need to do the dawes before you do the needle valve. I'll edit my post to make it more understandable. If fitting both, install the two together and set the dawes before the needle valve.
    The glow plug timer is something that does need to be done too. Something I need to do to my Patrol. Not to forget installing metallic tipped glow plugs too.
    Nov 2013
    Yes intercooler does appear to have minor leaks ! so you think needle valve first ? any recomendations for sourcing catch and plumbing?
  4. #13
    Heres a pillar pod for you to look at
  5. #14
    Unafordable
    4 Post(s)
    Boost and EGT gauge first, than catch can, than needle valve and Dawes valve together at the same time than the rest.
    For catch can try Ebay or Western filters ==> crankcase breathers ,they supply a kit, catch can with all the goodies like hoses, fittings, hose clamps whatever.
    e.g. -->
    Universal Provent kit 16 mm hoses
    + drain valve and hose kit personally I wouldn't get the drain valve with hose from them as it is a rubbish and overpriced though.
    The stop/ball valve is available from Bunnings and clear hose too all for princely sum of $10 plus couple of hose clamps. Hose is 10 or 12 mm.
    I got the replacement valve from "Industrial fittings" and I just sourced the catch can from them, rest I got from elsewhere.
    On mine 2005 Di the inlet end on turbo hose is 16 mm so I flipped OEM hose around to point to the firewall (backwards) and than rejoined its 16 mm end with another 5/8 (16 mm) hose via additional barbed 5/8 joiner to reach the catch can where another 2 reducers are needed to convert from 1" (25 mm) outlet/inlet on the Provent (so a bit of 1" hose is also required) to 16mm so you can run the hose back to intake hose. You'll need to measure the size of the pipe on your truck.
    See pics
    Provent close up
    Hoses run
    The whole view
    Decent drain valve
  6. #15
    465 Post(s)
    Quote Originally Posted by Mont View Post
    If your IC has leaks then when you instal a Dawes you wont be able to set the boost pressure right. Fix the leaks first then worry about the valves.
  7. #16
    Nov 2013
    Great pics mate much appreciated Also like the look of the pillar pod !
  8. #17
    Nov 2013
    Looks like intercooler is the first job then ?? any ones particularly good? well priced ?
  9. #18
    Expert oddkid82's Avatar
    Apr 2013
    Hey I have a diesel smart intercooler, all tig weld joins, 30 percent bigger core and only paid about $500.
  10. #19
    Unafordable
    4 Post(s)
    There is a mob on Ebay, replacement welded cores OEM intercooler for $380 or so and you can keep your old one, no need for core return. ==>
    NISSAN-GU-PATROL-ZD30-direct-injection-BRAND-NEW-HI-FLOW-upgrade-intercooler
    That's for budget minded.otherwise I'd go for pure ally welding porn intercooler from Cross Country 4x4. That one top of the line TMIC.
  11. The Following User Says Thank You to Rumcajs For This Useful Post:
    mudski (29th November 2013)
  12. #20
    465 Post(s)
    Nice CC cooler but at nearly 15huunge. Is it worth the coin?
