16th November 2013, 09:54 PM
shock bushes
just trying to fit a set of three inch amada extreme shocks to the gq and I cant get the lower nut on as the bushes seem to big or there isn't enough thread on the pin. Can I put the bushes/rubbers in boiling water to soften them up so I can compress them or is there another way, any help appreciated thanks! this is for the front as the rear went in easy as!
GQ Snorkle Lockers front n rear
16th November 2013 09:54 PM
17th November 2013, 10:59 AM
Has the rubber seated properly?
Also check thread length? Might be a reject.
Does it fit with old rubbers?? Might have bagged up the wrong size?
17th November 2013, 01:09 PM
Maybe you could try using the search button before starting a thread?
06 TD 4.2 coil cab, 3 inch lift, front ARB air locker.
17th November 2013, 01:21 PM
LachDiggityDog
G'day LDD, if you know of a thread, then please put the link on your post.
89GQ, try taking the washers off and start the nut on the thread. You may be able to compress the rubbers enough to get the nut started with the washers fitted.
89gqpatrol4x4 (17th November 2013)
17th November 2013, 02:31 PM
LachDiggityDog
LOL you have finally got to say it!
17th November 2013, 02:32 PM
Westy's Accessories
will go and have a look.
17th November 2013, 10:10 PM
1999 GU 4500 dual fuel
Il dado è tratto
18th November 2013, 05:27 PM
NP99
Thanks mate, I got them in the end. I compressed top of bottom rubber then held it with vise grips then got a bit of pipe and cut into it so I could put the nut through the side of it then using a jack put it on the bottom washer and jaked it up to compress the bottom washer and the I could put the nut on through the cut out in the tube. wow what a pain in the bum. I watched mudrunners 4wd tv episode and they don't go on that easily at all!!!!!
