Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: On Board Compressor
    Jan 2013
    On Board Compressor
    I have finally selected and installed an on-board compressor. I selected a Mean Green 2Air from Opposite Lock (they were on special). It pumps my tyres from 24psi to 30psi in 25 seconds.
    I have attached some images to show how I have installed it. I have used 6mm tubing to go to the pressure switch because the compressor is on the opposite side to the battery and it meant less wire. I ran the wire for compressor through 10mm loom tube with the 6mm tubing to make for a very neat finish. Power is connected to battery via 50A fuse and 40A relay. I have attached a circuit if anyone is interested.
    I also have an air point at the front on the bullbar (using 8mm tubing through grill). To prevent any dirt or muck getting into connector, I use 25mm chair leg rubbers from bunnings and a bit of foam hose.
    I no longer need to pop the bonnet to pump my tires up now.
    I hope this can be of some help to others.
  2. The Following 3 Users Say Thank You to angelo_f For This Useful Post:
    Malgreen (8th November 2013), taslucas (8th November 2013), Woof (8th November 2013)
    Jan 2013
    Just a note, connect the negative of the compressor straight to battery and not through chassis. The compressor draws more than 30A (I know because it blew 30A fuse - also, compressor specs say it draws 32.6A), and you don't want that much current going through your chassis for any period of time.
  5. The Following User Says Thank You to angelo_f For This Useful Post:
    jayisbikes (11th August 2014)
  6. #3
    You can use rubber door stops to cover the outlet from getting full of shite
    angelo_f (11th November 2013)
  8. #4
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    I've got a pump that looks exactly like that on here in UK land On mine the switch is on the pump. So if I can find a pressure switch I could do as you have , cool. Now where can I get a pressure switch ? Does it sense some tyre pressure to fire it up ? If so how does it work if the tyre is flat ?
    Electrickery is not my strong point ? lol
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
  9. #5
    The pressure switch is situated in the output side of the compressor and is pre-set so it will cut the compressor out when that pressure is reached. Angelo, where is the air filter for the inlet. I was going to run a hose and fit the filter inside the cab on the passenger side fire wall, but I mounted the compressor under a rear passenger seat.
  10. #6
    Expert Shaun 4x4's Avatar
    Secrets
    Quote Originally Posted by angelo_f View Post
    Why is this?
    i only ask as i run a twin arb compressor with the neg through the chassis and have had no problems, about 60A too.
    But do not want one either.
  11. #7
    Jan 2013
    Quote Originally Posted by makeitfit View Post
    I got the pressure switch off ebay
    http://www.ebay.com.au/itm/VIAIR-90-...item337cfa474a
    The way it works is like this (Keep the switch on the actual pump on)
    Initial condition -there is zero air pressure and rocker switch is off
    1 - Turn the rocker switch on and your motor (or accessories) on. Power runs from accessories through the rocker switch, through the pressure switch contacts, through the relay and energises the relay, thus closing relay contacts and allowing power through compressor.
    2- When the pressure in the system reaches the 'off' pressure on the pressure switch (int the case of the one I have shown in link - 120psi), the contact on pressure switch opens, causing the relay to de-energise, opening the relay contact and stopping power to the compressor.
    3- As you use the air, the pressure drops to below the 'on' setting (in the case of the one I have shown in link - 90psi), the contact on presure switch closes again and the relay is energised again turning compressor back on.
    Use an inflator with a gauge like this one to pump the tyres up.
    http://www.supercheapauto.com.au/onl...d=293784#Cross
    Also, make sure you use a relay and don't just use the pressure switch to supply the power. Those pressure switches are only rated at 20A
  12. The Following User Says Thank You to angelo_f For This Useful Post:
    makeitfit (9th November 2013)
  13. #8
    Are you running a tank??
  14. #9
    Jan 2013
    Quote Originally Posted by Shaun 4x4 View Post
    Why is this?
    Here is a good answer
    http://www.city-data.com/forum/autom...d-problem.html
    Basically, with that much current, you want as few points of contact as possible. If you connected through chassis, how much paint do you have there. You really should rub back to bare metal or you will get a voltage drop. When it gets wet, you will start getting electrolysis at those currents which could corrode in time.
    Better to just connect to battery
  15. #10
    Jan 2013
    No need to. Also, makes it simpler and uses less space.
