25th October 2013, 07:32 PM
Water cooled. Water proof alternators.
Gidday, All. I have spent the last week going over the Old Trol after taking it for an impromptu swim, or two or three. I have found some dried mud, grit and vegetation in the alternator. I am wondering if any one has fitted a water cooled alternator to their Patrol? I am getting my vehicle ready for more swimming, (as the tracks down my way are still very wet) and the standard alt is a definite weak spot. I have been looking at the Rover one but it has a different pulley.
25th October 2013 07:32 PM
26th October 2013, 07:43 AM
Wouldn't bother mate. It's all just overkill.
In 22 years and 500,000 k's my alternator has been serviced once..
If it was an issue I'm sure blokes would change it.
And why would you bolt an inferior product on? Lol
26th October 2013, 07:46 AM
Tie a safeway bag over it or do a Bosch conversion ,
I don't like Nissan Squirrel cage style alternators
prefer fully closed body
26th October 2013, 07:51 AM
Westy's Accessories
How many times has it been under water though?
Id be interested to look into other options as mine gets gets caked in mud
Hello from Under Down Under!
26th October 2013, 07:59 AM
threedogs
Some how I think the bag is a really bad idea as its open design is for cooling hence replacing it for a water cooled one
taslucas
X2 and a higher amperage would be nice also
The Following User Says Thank You to megatexture For This Useful Post:
mudnut (27th October 2013)
26th October 2013, 08:01 PM
Mine filled with oil when the vac pump seal went. Lol.
Flushed it out and is still working fine..
26th October 2013, 09:39 PM
Oil becomes a problem if it is left in an alternator, as it attracts grit and can cause the brushes to stick open, bearings seals to fail, and current to track where it shouldn't. I started the Old Trol today, after a week of having the doors open and carpet lifted around the edges to dry out. A bearing was making a terrible noise, and I have traced it back to the alternator. As I have said before, I will be hitting some pretty wet tracks, so an enclosed alt would be a good thing. I also read some where that they are brushless too. I am hoping someone has fitted one so I can pick their brains.
27th October 2013, 06:31 AM
what about one of these
why not get a A2 humvee alt. It has a 24 and a 12 volt output in the same alt
OH LEATHER IS NICE
![](image.php?s=71383f4fd17ab9203ca4207b578606f5&u=256&type=sigpic&dateline=1352567496)
The Following 2 Users Say Thank You to my third 256 For This Useful Post:
Bush Ranger (26th September 2017), mudnut (27th October 2013)
27th October 2013, 07:15 AM
Heres what I was going to do on my other 4x4,
get some stainless steel sheet cut and rolled to suit the shape of the alternator. "splash shield"
Tig some tabs to mount it close as possible still allowing it to "breathe",
should deflect most mud and crip going into it. They are 4x4 and they go places sometimes we shouldn't take them, but
you get that on the big jobs hey
Plus the rectifier only costs $20 if you do Bosch conversion not $80
27th October 2013, 04:36 PM
I pulled the alt off, this morning and pulled it apart. I was lucky enough to find that the brushes are only 2/3 to 3/4 worn. I had a matching bearing that fitted the pulley end. I popped the seals off and washed it out with petrol. After I blasted it out with air, I regreased it with Inox LM8 (Extreme pressure, marine grade. I will also be using this all purpose grease for the whole swivel hub and C/V joint) and put the seals back on. I couldn't get the small bearing off, so I popped its seals off, washed and regreased it in situ. Thankfully, the seals went back in easily. Hopefully it should now stand up to the punishment I mete out to it.
