Page 2 of 15 FirstFirst 123412 ... LastLast
Results 11 to 20 of 150
Thread: Sound dampening..
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Found the jaycar stuff. At 4kg per m^2 and the price is very cheap so might be worth putting a couple of layers down. Very intrigued.
    http://m.jaycar.com.au/m_productView.asp?ID=AX3680
  2. The Following User Says Thank You to Parksy For This Useful Post:
    NissanGQ4.2 (27th October 2013)
    43 Post(s)
    Good price, around $100 for the floor.
    But only 2.3mm thick.. I'll see if our local jaycar has Stock?
    43 Post(s)
    well just dropped into the local JayCar. Can get it, unfortunately no display piece.
    But he tells me its self adhesive, very pliable and heavy.. So good start.
    Might just get one square and see what its like..
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Parksy (25th October 2013)
  7. #14
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Hey I got this off the jobsite today it might be worth further investigation.
    http://www.spec-net.com.au/press/0310/ecow_100310.htm
  8. #15
    43 Post(s)
    Weird, they are using a different method.. Light weight density..
    How are we going to trial it cheaply??
    Mar 2013
    Westy I have about 4 square meters here. Mate the stuff is lightweight squashes together 4-5 mm and its has the foam and dyanamat . least if you put it under floor cover you can pull it out dry it.
  10. #17
    brisbane
    Would be good in the doors and use the self adhesive stuff on the floor
  11. #18
    Mar 2013
    Well this is what i figure, I think it would be better on the floor least you pull it out inspect yours floors and its not a permanent fixture. I'm thinking bout removing all the foam under my vinyl floor lining and running this under it. I've already completely coated the floor with body shilzs/sound deadner so the floor is sealed. So something like this would be ultimate pull out high pressure wash and let dry.
  12. #19
    43 Post(s)
    Will it work when compressed but?? You see all that style of dampener at 100, not squashed??
    Dunno, look forward to hearing some results. Lol
    Mar 2013
    Westy you figure out someway we an benchmark/test it haha
  14. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    BigRAWesty (26th October 2013)
