Page 1 of 7 123 ... LastLast
Results 1 to 10 of 66
Thread: Coffee on the run
    Coffee on the run
    Hi all been using these a while now, not sure if available Aust wide.
    They come in different flavours latte, cupachino, Mushroom soup and hot chocolate.
    All you do is press the bottom shake for 20 seconds then let stand for a minute or to and you have a nice hot drink.
    Great if you don't have stove or wood is wet, @ only $2.50 a can I'll be throwing a few in my tucker box. I brought this from the reject shop. but check HOT CAN on line for nearest stockist, seems to be Vic regional , Handy for a quick coffee hit,
  2. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    NP99 (13th October 2013), PMC (15th October 2013)
    43 Post(s)
    And quite nice hay.. Seen them in target to..
    Expert janderson's Avatar
    Bearii Vic
    will have to look out for these
    1st G60 Then MQ Now GU
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Where are they imported from John?
    1999 GU 4500 dual fuel
    Il dado è tratto
    43 Post(s)
    They do all sorts to. Even hot chocolate..
    Bearii Vic
  9. The Following User Says Thank You to janderson For This Useful Post:
    BigRAWesty (14th October 2013)
  10. #7
    Has Malaysia on the can.
    @ Janderson they are available from the independent servo on the South side of shep, United I think
  11. The Following User Says Thank You to threedogs For This Useful Post:
    NP99 (14th October 2013)
  12. #8
    Bearii Vic
    Thanks for that. Next time in town I'll check them out
  13. The Following User Says Thank You to janderson For This Useful Post:
    threedogs (14th October 2013)
  14. #9
    Or you could just do a Mego Special
    2kva Hona genset powering an Aldi Expresso machine getting a workout at Knockwood! There was a que!
  15. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (14th October 2013), threedogs (15th October 2013)
  16. #10
    Oct 2011
    Essendon
    Man, that setup was outrageous.
    You've gotta love your coffee to be hauling around a genie to brew it!
    I use a stove top percolator in the bush and it works a treat.
  17. The Following User Says Thank You to Drewboyaus For This Useful Post:
