Results 1 to 10 of 19
Thread: Underpowered tb42 auto!
    Advanced coolummatt's Avatar
    Jul 2013
    Sunshine coast
    Hi all. Can anyone help me. I have a 96 tb42 auto. I've only had it a couple of months now and I have notice some times on the beach it can be a little underpowered in soft sand. Even in first gear with my foot flat it doesn't want to rev over 2000 rpm. It has not been to much of a problem yet but adding a camper trailer at 750kgs im a little worried im going to get stuck.
    Also today I picked up my new camper trailer. Seems to tow really well on the hi way until I get to a hill the it just dies in the arse quickly. Is this normal?
    Thanks.
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Gday mate, the tb42 should rev way higher than that. Is it dual fuel? If so, does it do it on both fuels?
    I would check the ignition and fuel side of things to make sure everything is in good working order. Points, rotor button, distributor cap, leads, spark plugs, coil and timing should all be checked. Also check the fuel filters. There will be one in the engine bay and usually another one closer to the fuel tank. If they are clogged the engine will lose power. Look for any vacuum hoses that may have come off (around carby and intake manifold, and also the vacuum advance to the distributor). Also wouldn't hurt to inspect the carby for anything obvious problems and give it a good spray with crc or similar to lube up all the linkages.
    Hello from Under Down Under!
    Jul 2013
    Sunshine coast
    I should have mentioned its an efi. Also it drives fine on the road and will rev all the way to red line with no problems. It only seems to be in deep boggy sand that it wont rev.
    Jul 2013
    Sunshine coast
    Oh sorry its petrol only
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    what tire pressure are you running in the soft sand as this can restrict the car from accelerating, also i would put an injector cleaner through it easy enough to get from car shops and some service stations, and as lucas said check all fuel filters ans when was the last time the air cleaner was checked??
    for added measure i would take the air intake hose off and clean the throttle body with some carby cleaner you might find it to be a bit dirty with carbon and such best to do this whilst its running
    Jul 2013
    Sunshine coast
    Thanks I will have a look at that today. I run about 25psi on the beach
  8. #7
    Expert 92GQ's Avatar
    Sep 2013
    Qld
    Quote Originally Posted by coolummatt View Post
    What size tyres are you running at 25psi?
    1992 TD42 GQ Patrol Wagon
    My GQ Build Page
  9. #8
    Aug 2011
    North West Tas
    56 Post(s)
    Even on 35s at 25psi it should rev past 2000rpm in first?
  10. #9
    Jul 2013
    Sunshine coast
    Im running 32 AT
  11. #10
    Dec 2012
    Bunbury
    But if it's a hungry beach it's still going to struggle go down to between 15-18 psi you'll find it a lot easier and you won't put so much pressure on your drive train
