Results 21 to 30 of 40
Thread: Shock absorber advice
    43 Post(s)
    This is my 2" OME about 3/4 flex...
    Rear factory disconnect disconnected, but front sway bar still fitted..
    I have removed front sway bar it it is alot nicer and gained another 50mm I reckon..
    I would love the front of my car to flex like Darren's but my front does not flex much at all.
  4. #23
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Still got your front sway bar fitted?
    Hello from Under Down Under!
  5. #24
    Yep, and rear lmao.
  6. #25
    Aug 2013
    Perth
    Hey MudRunner,
    Those measurements were fully open. Sounds like the Amada and Profenders would be the way to go. Did you purchase the 2" flexy coils when you had them on your truck? I'm not really keen on blowing decent shocks either, so if you did, I'll probably have to get bump stops and see if that helps.
    Also how much did you extend your brake lines when you had the flexy coils?
    Thanks very much for your help mate. This is why I joined the forum. Haha. Cheers
  7. #26
    brisbane
    You won't notice the front removed on road, but you will the rear
  8. #27
    Quote Originally Posted by megatexture View Post
    My old one had the rear disconnects, but this one doesn't. I might just take the front ones out then?
    Sent from my iPad using Motorculture mobile app
  9. The Following User Says Thank You to Winnie For This Useful Post:
    BigRAWesty (14th September 2013)
  10. #28
    Aug 2011
    North West Tas
    56 Post(s)
    Can just undo them and take it for a drive to see if it's still half decent on the black top
  11. #29
    Might just unbolt them when I go away and cable tie them up, leave them on when on the road.
  12. #30
    brisbane
    I've removed my front and the rear is broken for the 2nd time , just unbolt one side so you don't have to zip it up
