10th September 2013, 10:32 PM
Exhaust Jack VS High lift
G,day, I do mostly sand off road, leaning towards a exhaust jack w compresser adaptor.
Weight, storage, usage are my issues.
Maybe run a poll on this? HA HA
Let the debate run its game? maybe old thread not seen yet.
Daz
10th September 2013 10:32 PM
10th September 2013, 10:52 PM
Moderator
Check out my Toy -->
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
Bluecrab (18th December 2013), Gecko17 (10th March 2014)
10th September 2013, 11:44 PM
Bitumen Burner
This is what I've got.
It's the first lift and I was practicing. lol
Whatever you decide, read and understand the instructions BEFORE commencing the lift, and treat the equipment with respect and use it safely.
Thinking about it.....an exhaust jack will provide a bigger 'footprint' in the sand. My main concern of using a hi lift on sand is stability of the jack when extended on a base plate. I'm concerned it may tilt a little way, or a lot. I'm more than happy with an exhaust jack. Both pieces of equipment require user vigilance and absolute safety and care, and should not be used in conjunction with alcohol - in any shape, form or quantity.
Rossco
The Following 2 Users Say Thank You to DX grunt For This Useful Post:
11th September 2013, 12:10 AM
Dribble Master
DX grunt
Rossco
That'll be the first time you ever got DX off road isn't it mate!!!!?????? Hahahahahahaha
End of hijack
11th September 2013, 12:49 AM
1999 GU 4500 dual fuel
Il dado è tratto
11th September 2013, 01:05 AM
I use a high lift and agree they are deadly when used incorrectly, but would rather be caught out with a high lift over a exhaust jack. I also carry a 400x 400 x6 mm steel base plate for sand and works for me.
The Following User Says Thank You to megatexture For This Useful Post:
11th September 2013, 08:04 AM
Hi lift jacks are dangerous if not treated with respect, as Mega mentioned you'll need a base plate for sand work. Always leave a hi-lift with the handle in the up position.
Modern 4x4 are not really made with a hi-lift in mind having being coil sprung you'll be lifting it for ages to get a wheel off the ground, but there are gizmo's to lift via the wheel,.
exhaust jacks on the other hand are perfect for sand work, practise how it works and where to place it, Only down side is storage being a little bulky, but great piece of recovery gear.
treated well should last for years.
11th September 2013, 09:09 AM
Get both and then you won't have to decide....
11th September 2013, 04:12 PM
I got a hi lift.. Kinda wish I get an exhaust jack first... As there are few places u can use the hi lift unless u have solid bar work.. But have got the hi lift tyre mate which is a perfect accesory to the hi lit..! But my advice for some would be to go an exhaust jack first..!
The Following User Says Thank You to TJsGQ For This Useful Post:
11th September 2013, 05:08 PM
I think people really dont understand how to use a high lift properly including myself.... I would love to have a much better understanding as with towballs I am sure many people are hurt from these things also!!!
The Following User Says Thank You to Bloodyaussie For This Useful Post:
