9th September 2013, 09:06 PM
#21
Smart like tractor
Drewboyaus
Where did 2300 come from?
I've just gone and compared it to the one from that Nissan forum and he's getting 6300 for his TE figure and I reckon that's more like what you should be seeing based on how much power you're making.
Tip tip tip......tap tap tap....
1700 ft lb ( as per dyno sheet) = 2300N
96 GQ coil/Cab
08 G6eT
9th September 2013 09:06 PM
9th September 2013, 09:09 PM
#22
nissannewby
You have about 660-670nm now. Before hand you maybe had 500
G'day Killer-Wasp,
You have to always bring sex into some of your posts! (660-670nm) lol
Regards,
RLI
The halls been rented the bands been paid, time to see you dance!
9th September 2013, 09:12 PM
#23
Ben-e-boy
Newton Meters is at the flywheel and Newton tractive effort is torque at the wheels as torque is multiplied by gearing
Fark, your another one,Ben-e-boy, has to bring sex into the equation. lol
Regards,
RLI
9th September 2013, 09:24 PM
#24
Ben-e-boy
Right, so the equation is
TE= (T × R × 1000)/r
TE=2300
T= ?
R=4.11
r=412.5
Have a crack and see what you get
There is more too it than that. It's not as simple as that equation would make it seem. Just do what I did and ask someone smarter lol
9th September 2013, 09:27 PM
#25
CERTIFIABLY INSANE
A bit more reading and the equation asks for the Torque figure in Kg/mm. How does that affect the final figure?
9th September 2013, 09:34 PM
#26
nissannewby
lol
I was thinking the same.. Your diff ratio is 4.11 but that wouldn't be the figure your after..
You would need to also add in the gear box ratio, sure they try get 1:1, but I think it's a little Off from that..
9th September 2013, 09:40 PM
#27
Smart like tractor
nissannewby
lol
What does that person have,
96 GQ coil/Cab
08 G6eT
9th September 2013, 09:41 PM
#28
Ben-e-boy
smarterness
Hello from Under Down Under!
9th September 2013, 09:49 PM
#29
Smart like tractor
Drewboyaus
Lots, I just used a converter to Nm and its 2.25 lol
96 GQ coil/Cab
08 G6eT
9th September 2013, 10:02 PM
#30
CERTIFIABLY INSANE
Ben-e-boy
Hahahha......might have to start a new thread "the 2 and a half killer wasps" hahahahh.
It would be interesting to see if there is another version of the equation to be found on the Internet.....
