9th September 2013, 06:20 PM
Hurls, I've got plenty of pulleys in the shed if you need them.....
1999 GU 4500 dual fuel
Il dado è tratto
The Following User Says Thank You to NP99 For This Useful Post:
lhurley (9th September 2013)
9th September 2013 06:20 PM
9th September 2013, 06:22 PM
mudski
- Doing mine right now!! Well just stopped as I was given the wrong bearing from the bearing shop. On my ZD30 all that needed to be removed is the radiator shroud and belt.
- you need to remove the cover plate using 3 x, 5mm x 35mm bolts, so...
- On the face of the compressor there is a 10mm hex nut in the middle, undo this, but after you have screwed in the three bolts as you also need these as leverage with a screw driver to stop the pulley from spinning.
- Once the nut is off, even go around the three bolts to push out the cover plate.
- Once its off there is a circlip, remove circlip.
- then you will need a gear puller to remove the pulley.
- Once off all you need to do is press out the old bearing and replace.
- Then put it back together.
- Took a whole 15 minutes to get totally apart. Between beers of course.
- But now it has to go back together with a foobar bearing as I need my car so lets hope it last until I get the right bearing.
This is all for a ZD30 but most A/c pump should be along the same lines of some sort I would think...
Thanks for that. Would it make it easier to pull the clutch off with a puller similar to what NP99 posted a pic of or not needed??
I am assuming the bearing is in the pulley?
I wish i had of got motivated to look into this last week as i only just had the rad out to clean it
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me
9th September 2013, 06:25 PM
NP99
Thanks mate. Now i know its not a massive job i should be right. I have a bearing shop about 2 mins from my house so it shouldnt really be an issue. A mate has a press too. But i will remember that just incase i come unstuck. Plus my missus's old man has just about every tool under the sun
9th September 2013, 06:28 PM
No worries, enjoy the job! Could you also publish the bearing part no prior to installation?
PM sent
Il dado è tratto
9th September 2013, 06:39 PM
NP99
PM sent
No worries. I will try do up a how to.
I just looked at my compressor and the manual, and i will need 2 different pullers. Oh no what a shame more tools
9th September 2013, 07:22 PM
I'll post up some pics later on if it helps...
NP99 (9th September 2013)
9th September 2013, 07:42 PM
#17
mudski
Thanks mate. No rush. Got to wait for pay day first
