Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: tractive effort to Newton Meter
    Have you had it tuned Benny?
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Can someone explain the difference between the two in layman's terms?
    Hello from Under Down Under!
  4. #13
    22 Post(s)
    Yep the dyno sheet is in the killer wasp thread.
    96 GQ coil/Cab
    08 G6eT
  5. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    PMC (9th September 2013)
  6. #14
    22 Post(s)
    Newton Meters is at the flywheel and Newton tractive effort is torque at the wheels as torque is multiplied by gearing
    96 GQ coil/Cab
    08 G6eT
  7. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    PMC (9th September 2013), taslucas (9th September 2013)
  8. #15
    Aug 2011
    North West Tas
    56 Post(s)
    Ahhhh, cheers, so it's pretty straight forward. Just like kw and rwkw?
    How would one ever measure in newton metres? That would only really be factory specs unless you pull your donk out and put it on engine dyno?
    So all dyno figures are in Newton tractive effort torque.
  9. #16
    22 Post(s)
    Right, so the equation is
    TE= (T × R × 1000)/r
    TE=2300
    T= ?
    R=4.11
    r=412.5
    Have a crack and see what you get
    96 GQ coil/Cab
    08 G6eT
  10. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  11. #17
    22 Post(s)
    Year pretty much, I think some dyno programs can work out Nm
    96 GQ coil/Cab
    08 G6eT
  12. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  13. #18
    Oct 2011
    Essendon
    Ok, so I get 230. That still seems a bit light on.
    Looking at the equation, 2300 seems a bit low if that is the TE number. Based on your ratio (known) and wheel diameter (known) and there is a constant (x1000) the key number is that TE value of 2300.
    Tip tip tip......tap tap tap....
  14. #19
    22 Post(s)
    Thats what I have been getting, less than a factory NA
    96 GQ coil/Cab
    08 G6eT
  15. #20
    Oct 2011
    Essendon
    Where did 2300 come from?
    I've just gone and compared it to the one from that Nissan forum and he's getting 6300 for his TE figure and I reckon that's more like what you should be seeing based on how much power you're making.
