Results 1 to 10 of 13
Thread: Ignition coils
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Ignition coils
    Hi all
    Is there a difference with ignition coils on the tb42s and tb42e models? Looking at them on eBay and the ones suited to a tb42e(which I'm after) appear to have a plug like socket, where as the tb42s coils only have terminal connections. Now my problem is the coil in my car appears to be an aftermarket unit with the terminal connections and the plug connector is long gone(I'm assuming).
    Can someone shed some light on this by taking a picture of their setup on their tb42e?
    This is the coil suited to a tb42e
    http://www.ebay.com.au/itm/271240265260?redirect=mobile
    Jan 2013
    Nowra NSW
    5 Post(s)
    Here's a pic of what's on my tb42e.
  4. The Following User Says Thank You to Parksy For This Useful Post:
    no eye deer (9th November 2014)
    Thomastown, Melbourne
    6 Post(s)
    At an appointment but as soon as I am out I will take a pic of mine.
  6. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Parksy (15th August 2013)
  7. #4
    6 Post(s)
    And that is the right setup in your pic..
  8. The Following User Says Thank You to Bloodyaussie For This Useful Post:
  9. #5
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Looks a lot different to the one for my TB42s. Is it possible that there are a few different shapes for different brands but they are still suited to your engine?
    Edit: BA is your man.....
    Hello from Under Down Under!
  10. The Following User Says Thank You to taslucas For This Useful Post:
  11. #6
    6 Post(s)
    I have 2 efi gq's and they both run that coil pictured. .....
    The S uses the cylindrical type one.
  12. The Following 2 Users Say Thank You to Bloodyaussie For This Useful Post:
    Parksy (15th August 2013), taslucas (15th August 2013)
  13. #7
    Jan 2013
    Nowra NSW
    5 Post(s)
    Thanks all. I wasn't sure if it was right due to the fact that it's a Bosch unit with what looks like extensions on the leads. But all good by the sounds of it.
  14. #8
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    Hi Parksy, tb42 basic coil and tb42e module type
  15. The Following User Says Thank You to Pezzer For This Useful Post:
  16. #9
    Jan 2013
    Nowra NSW
    5 Post(s)
    Thanks pezzer, great picture. I can see what colour wires go where which helps a lot if I ever buy a coil with that plug.
  17. #10
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    mmmmmmmmmmm
    My car is at the smash repairers so can't check it until Saturday
    I'm pretty sure my EFI has the one pictured in your link
    Your current one doesn't look to be original and buy the look of those wires you definitely have an aftermarket one which didn't have the plug fitting so they just cut the wires and made up what they needed.
  18. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
