Results 1 to 9 of 9
Thread: What does this item do ?
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    Need some help determining what this item controls, any help?
    Does not look standard? Is that on the firewall? Where do those tubes go?
    Jun 2013
    Gold Coast
    Yes its on the fire wall the wiring goes to the Lpg converter 1 hose picks up on the air intake before the sensor and the other?
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Is it an idle control for when the aircon goes on?
    Hello from Under Down Under!
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    looks like an air flow/boost sensor.
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
    Jun 2013
    Gold Coast
    If it was A/C related would it not be a genuine part as the aircon is still all Nissan.
    Jun 2013
    Gold Coast
    So where would the pressure hose go to?
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Trace the vacuum? Hoses. Where do they go, I had a gas system that had a vacuum solenoid in the air intake to restrict airflow when on gas.
  10. #9
    Jun 2013
    Gold Coast
    The Lpg guy suss it, its a MAP sensor he will sort it today whilst connecting up the gas.
