12th August 2013, 08:23 AM
GU Td42t Fan change,,, any advice
Im changing the fan on my Td42t today and was just wanting to know if i need to remove the radiator and fan shroud to do it or is it possible to reach around the front of the fan to undo the bolts without removing the above items, any advice from people who have changed a fan before would be appreciated,,,, Cheers
12th August 2013 08:23 AM
12th August 2013, 11:52 AM
Hey mate just remove the shroud, it should be a couple of bolts and the bottom section unclips from underneath. You could do it with the shroud in place but it will be a hell of a lot easier without it.
12th August 2013, 01:57 PM
I also removed the shroud....you'll be cursing if you don't.
Mic
