Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: EGT gauge and boost gauge installer in MELB
    Expert Limmy's Avatar
    I ended up pulling the dump pipe off . Got bung welded in . Costed me $15 from Havoc Fabrications in keysborough .
    Thanks for the confidence guys . I saved a bit of money without getting someone to remove/install . learning how to pull the car apart now . Apart from some rounded nuts and broken bolts along the way
  2. The Following User Says Thank You to Limmy For This Useful Post:
    threedogs (8th June 2013)
    465 Post(s)
    Well done. What about the skinned knuckles? Did you gut the cat too?
  5. #23
    yeah couple of battle wounds. The heat shield was easy to take off though . I looked up instructions on the forums, did it within 30 seconds. nah didn't gut the cat , I'm going to wait and get full stainless steel exhaust done
  6. #24
    465 Post(s)
    No need to pay extra for stainless mate. You won't notice any difference except for the price.
  7. #25
    yeah be a while before i get exhaust done, i suss out the prices then . need to budget for new tyres soon
  8. #26
    465 Post(s)
    Mild steel is all you need. Mandrel bent so the exhaust flows better and the Cat needs to be Hi-flow and have a metallic filter, not ceramic.
  9. #27
    Finally all egt and boost gauge installed.
    I was maxing about 15 PSI. Cant seem to go over 15psi.maybe i got a leak. ( no dawes yet )
  10. #28
    Advanced batesy's Avatar
    cranbourne vic
    probably try biders 4wd in cranbourne they seem pretty good.
  11. #29
    Adelaide Hills, SA.
    Biders 4WD, Cranbourne, give them a call to quote price
