9th June 2013, 02:16 AM
DIY Rear wheel bearings & seals
Hi all. In the next couple of days (if i get time) im going to be replacing my rear wheel bearings & seals. Would any one be interested if i posted some shots & step by step guide on how its done using only general tools @ home ?????
The Following User Says Thank You to jgoose For This Useful Post:
dom14 (20th November 2016)
9th June 2013 02:16 AM
9th June 2013, 02:34 AM
Moderator
Not a job for home mate sorry, they really need to be pressed off and on. Front no probs but the back are not
![Cool](images/smilies/cool.png)
Check out my Toy -->
Rogue Dung Beetle
9th June 2013, 08:39 AM
The seals are easy to replace but the preload on the bearing is something like 240ft/lbs...
9th June 2013, 08:48 AM
I'd be interested if you do have a way that can be easily done at home.
9th June 2013, 04:50 PM
MudRunnerTD
Hi im a field service plant mechanic & have been doin this sort of thing for 30 odd yrs on site with out any presses etc & never had a failure. As i cant carry everthing on my truck i need to improvise with what i have on board granted sometimes ive had to make some tools along the way but always get it done..
9th June 2013, 04:57 PM
Parksy
Hi parksy. Hopefully all going well tomorrow ill knock it over & take a heap of pics & explain what im doing & post it obviously things can be made easier with presses ETC but not all ppl can afford to buy a press or send it to a shop ive been working field service for over 30yrs on earth moving equipment ETC
9th June 2013, 06:20 PM
hi mate I am keen to see some pics
01 gu td4.2t wagon factory turbo 2" lift, 3" exhaust,snorkel,awning,uhf,egt & boost gauges,16"black round hole dynamic rims with 285 bighorns with more to come, ,air compressor,rear led work lights,winch, ready to fit up
9th June 2013, 07:10 PM
#8
Moderator
jgoose
Hi mate, I read your post to mean you were asking for advice on how it can be done at home? a second read today and your offering to produce a DIY on the process.
Sorry i responded to you as a newby, which is reasonable and this is generally not a job to be attempted as a newby to tools and home maintenance. Your obviously Not a newby as you have since explained.
Hell yeah mate, show us how its done at home. would be very keen to see it laid out as i recently had the rear diff stripped and stopped short of attempting that in the driveway.
Look forward to the pictorial.
Cheers MR
Rogue Dung Beetle
9th June 2013, 08:17 PM
#9
Alitis007
Hi ALITIS007 From memory. The bearings get tensioned up to about 350ft-lb. Then lock it off. Then use a spring tensioner gauge & check the rotational torque which needs to be around 5 lb.
9th June 2013, 08:22 PM
#10
MudRunnerTD
Cheers MR
Hi Mud. All cool mate its not that hard really just time consuming if you dont have a press etc but it is possible. Ill try n get some good clear pics
MudRunnerTD (9th June 2013)
