Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 89
Thread: Changing glow plugs... NEK MINNET
  1. #41
    Cool hopefully the GQ will be up and running again soon.
    Is your battery on charge while you're waiting ??
    Legendary Alitis007's Avatar
    15 Post(s)
    Bursons had the insulators but dear for what they are.... 6 bucks! Better than buying new plugs I guess.
    Got a fusible link coming from Patrolapart, could not find them anywhere else from local wreckers or even nissan themselves.
    Just go to an auto elec and buy the fusible link wire and retrofit it into the holder??
  4. #43
    Doesnt matter now, got one coming from Patrolapart. Cheaper than one glow plug isolator!
  5. #44
    15 Post(s)
    You might get it for free plus it wont hurt to keep an assortment of fuses, fusible links, terminals and bulbs in the glove box " just in case"
  6. #45
    Maybe you should have got a pack of 10
  7. #46
    Should have stuck to petty Pooh lol
    They call me MCcrappatappalot!!!!!
  8. #47
    Blasphemy!
  9. #48
    Just put isolators back on and used a wire to go from the battery to the glow rail.... nothing. I still have not replaced the fusible link yet as it's still on its way. Read this on another forum "glow and fuel shut off solenoid run off the same fuse" is that true? So if I don't have that fuse then it won't start at all?
  10. #49
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    That's not the main fusible link they are talking about that's the fuse in the fuse box inside the vehicle I asked you to check.
    It's the 15 amp fuse on the left hand side five down from the top. With ignition on does this fuse have power on both sides?
    Have you checked for power at the solenoid on the injector pump?
    You do have plenty of diesel in the fuel tank?
  11. #50
    What have you done Winnie......
