7th May 2013, 04:13 PM
#21
7th May 2013 04:13 PM
7th May 2013, 07:15 PM
#22
Simpson Desert
Alitis007
High tensile steel is 8.8 t the normal is 7 i think. Normally they're black steel but the zinc coated ones are silver so they don't rust as fast. Stainless would be better coz they're a bit stronger but will cause electrolysis (rust). But when you go to the bolt shop ask to try it in the chassis first to make sure you've got the right thread pitch!
Not looking for an argument, but don't use use ordinary stainless bolts, as they are actually weaker than mild steel bolts.
The Following 2 Users Say Thank You to GUtsy ute For This Useful Post:
Alitis007 (7th May 2013), threedogs (9th May 2013)
7th May 2013, 07:21 PM
#23
GUtsy ute
I didn't know that about stainless bolts, i was going by 3mm stainless 304 plate is as strong as 5mm mild steel. Cheers for the heads up mate!!
7th May 2013, 07:27 PM
#24
GUtsy ute
I actualy thought that but i then thought i must have been wrong lol. Stainless is more brittle
Hello from Under Down Under!
7th May 2013, 08:14 PM
#25
Stainless is infact softer than mild steel..
Its the compound of which its made that makes it feel stiffer and heavier.
Once stainless is heated and cooled it becomes more brittle. That's why you have to be careful not to work harden stainless when drilling.. slow and steady and lots of fluid..
Owner of
Westy's Accessories
The Following 3 Users Say Thank You to BigRAWesty For This Useful Post:
Alitis007 (7th May 2013), GUtsy ute (8th May 2013), taslucas (7th May 2013)
7th May 2013, 08:17 PM
#26
The Following User Says Thank You to taslucas For This Useful Post:
BigRAWesty (7th May 2013)
7th May 2013, 10:50 PM
#27
taslucas
I only had three bolts on the old alloy bar and they were cr@ped out anyway. Ill grab some tomorrow, cheers for the help georgina
You shmuck Lucy the whole point of getting the bolts was for you to get the thickness, length and thread pitch!! And no dramas any time!!
7th May 2013, 11:04 PM
#28
Dribble Master
Well I'm glad I didn't see this thread earlier otherwise I would have given you the right answer but now, I just can't be fecked roflmfao
Don't slap it, tap it!!!!
8th May 2013, 11:22 PM
#29
can i suggest you go for GR8.8 galvanized bolts , these have a coating of around 50 microns of zinc, the zinc bolts only have about 5 microns and will rust quicly when exposed to the elements
The Following User Says Thank You to bugster For This Useful Post:
8th May 2013, 11:34 PM
#30
got an m14 - 1.5 bolt today to test the captive nuts in the bar. No go, its too thick. The bar looks like and ARB but im not %100 sure. Would all ARB bars have the same size bolts?
