7th May 2013, 11:01 AM
Im Dumb, what bolts for my bull bar?
Yep Im dumb. I left my old bolts out at my parents house. Im going to buy some nice new shiny ones but what type? Is it M16 or something? im dumb about this stuff. I plan to buy the toughest ones i can afford.
I will go get them as soon as i get a serious answer out of one of you (which will be a while knowing you lot! Growlers, Scotty, Winnie, Clunk, Nisshead, Georgina need not reply!!)
Hello from Under Down Under!
7th May 2013 11:01 AM
7th May 2013, 11:15 AM
Well Lucy if you had a GU i'd say 110% they would be M14x 1.5 zinc coated high tensile bolts with flat and spring washers, the length should be about 30 - 35mm.
They look like this
The Following User Says Thank You to Alitis007 For This Useful Post:
7th May 2013, 11:17 AM
SUCH IS LIFE
HAHAHAHHAHAHHAHA
________________________
______ 2017 D-Max _______
The Following User Says Thank You to Maxhead For This Useful Post:
7th May 2013, 11:37 AM
Thanks George that looks like the ones!
Next Question: Whats the best type? It would be the ones with the strongest sheer rating? is that even what you call it??
7th May 2013, 11:38 AM
Nisshead
HAHAHAHHAHAHHAHA
Get a job!!
7th May 2013, 11:44 AM
taslucas
High tensile steel is 8.8 t the normal is 7 i think. Normally they're black steel but the zinc coated ones are silver so they don't rust as fast. Stainless would be better coz they're a bit stronger but will cause electrolysis (rust). But when you go to the bolt shop ask to try it in the chassis first to make sure you've got the right thread pitch!
7th May 2013, 11:46 AM
Sweety dont be so hard on yourself!!!!!!
7th May 2013, 11:47 AM
Bloodyaussie
oh i forgot to put you on the list at the top Jonathan! lol
7th May 2013, 11:49 AM
Alitis007
Yeah i was just going to go buy one and see if it fits before getting the rest. Ill see what they've got in their limit stocks lol
7th May 2013, 11:53 AM
I forgot your not driving it daily anymore lol just go grab an original from you parents place or use one off the front recovery point to see if they are the same, i think they should be.
