Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Home Built Cargo Barrier
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    That is bloody brilliant Alex, great job mate, you should be proud of your efforts and idea mate, Absolutely love it. Good work,
    TAPPN OUT
  2. The Following User Says Thank You to wildgu6 For This Useful Post:
    altech (2nd April 2013)
    Brisbane
    Thats awesome
  5. The Following User Says Thank You to leadsled For This Useful Post:
    altech (6th May 2013)
  6. #23
    Quote Originally Posted by altech View Post
    Hi Guys just a update , just put a Vid up on youtube , unit still need some modifcations maybe a gas stud or spring to up it raise quicker regards Alex
    http://www.youtube.com/watch?v=kaEmk...ature=youtu.be
    very clever mate, does it rattle on the road at all?
  7. #24
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    No ,not at all as you can by the video that I made up a spacer made from 3mm scarp wood and left over carpet and glued it on both sides , so it fits frame and perpex no rattle . and the perpex only go's up when needed . eg camping .. regards Alex
    http://www.youtube.com/watch?v=TceKoWcsjY4
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  8. The Following User Says Thank You to altech For This Useful Post:
    trekster (12th May 2013)
  9. #25
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Mate the steel you found is called unistrut, it's the mechano set og building material. The railing supports hundreds of different types of clips for everything, I love the stuff.
    Have look in this direction ,
    https://www.google.com.au/search?q=unistrut&client=firefox-a&hs=bVv&rls=org.mozilla:en-USfficial&source=lnms&tbm=isch&sa=X&ei=qqC8UYDjDIbRk gX2yoG4CQ&ved=0CAkQ_AUoAQ&biw=1920&bih=976
  10. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    altech (18th June 2013)
  11. #26
    Nov 2011
    Rupanyup, 3388, VIC
    Cheers Mate that's the stuff and the steel was free , left over from work site.......... lol
  12. #27
    Quote Originally Posted by sil3nt_dr3ams View Post
    Yeah unistrut is awesome stuff, I've made a few things out of it before, we have it at work
    If you're happy and you know it tap a post!
  13. The Following User Says Thank You to Winnie For This Useful Post:
    altech (26th July 2013)
  14. #28
    Jun 2013
    Thats a tops idea mate
  15. The Following User Says Thank You to soronation For This Useful Post:
