Results 1 to 10 of 10
Thread: Don't use AIR CON, want to remove system. What can I take out, what needs to stay
    Expert soulburner2000's Avatar
    Feb 2013
    Sunshine Coast (Buderim), QLD, AUS
    Hi. GQ auto on dual fuel. Air con has never worked since purchase, and I don't want it on the vehicle.
    Can anyone tell me what's good to remove as well as what needs to stay. It doesn't look like too much needs to stay - compressor maybe?
    Do your research. Learn the rules. Learn the game. Be successful.
    remove all of it. take out the compressor and do a Net search on converting that compressor to an Endless air and refit it. In a heart beat! 4cfm your done.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    soulburner2000 (27th April 2013)
    43 Post(s)
    X2 with Mr. Keep the compressor and turn into endless air.. those compressors crank 400L/m and above 600psi I have been told.. stuff ya arb junk... this'll pump a flat 40" tyre up in 30 seconds...
    Owner of
    Westy's Accessories
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
  7. #4
    Feb 2013
    no worries guys, thanks for that. Seems to be a decent amount of info around on endless air conversion - I'll check it out
  8. The Following User Says Thank You to soulburner2000 For This Useful Post:
    BigRAWesty (27th April 2013)
  9. #5
    Once converted you can use rattle guns out in the bush, I used the one on PGS comp truck years ago
    awesome amount of air, would recommend fitting and air tank, but yeah great accessory to have, You could air
    up 4 trucks in under 15 mins, great for cleaning air filters, you name it.
  11. #6
    Feb 2013
    so much more room to work already....
  12. #7
    I thought they were ok to use straight off but needed some kind of lubrication
    and away you went, but at least you'll have all brackets,
    Highly recommend keeping compressor for endless air style air,
    101 uses out in the bush , plus if you go this way plumb in front and rear
    outlets, from a tank with a pressure switch, you'll love it.
  13. #8
    Feb 2013
    it's plugged and in storage for now....got bigger fish to fry before I get to 'wants'
    Last edited by soulburner2000; 29th April 2013 at 02:50 PM. Reason: spelling correction
  14. #9
    Patrol Guru
    Apr 2011
    Melton
    You only needed to remove the fan belt (and only if the bearings where noisy). The rest could have stayed on the truck - unless you needed the space for another project.
    I surprised you removed it considering where you are located.
    Personally I would have had the system fixed
  15. #10
    Feb 2013
    It didn't work when I purchased the vehicle, and just kept getting in the way when I was working on other stuff. Much more room in the engine bay without it all in there and it can always go back in if I change my mind. Won't be for a while now though - I deregistered it a week or so ago as I was sick of trying to fix the auto. Bought a suzuki swift to get around.......will go back to the Patrol in a year or 2 and try again.
