20th April 2013, 09:14 PM
sealant for a snorkel
Hi all whats the best sealant /silicone to use when installing a snorkel as the standard silicone stuffs up the MAF sensor ive only ever made mine out of stainless in the past & havnt had to use it
20th April 2013 09:14 PM
20th April 2013, 09:15 PM
Not sure if RTV is odourless,
20th April 2013, 09:23 PM
Im not sure either im going to try n find some tomorrow but ive lost my sense of smell in a work acco so i need to rely on the pimply faced kids that half the stores emply now days i just thought id ask & hopefully save the pain
20th April 2013, 09:31 PM
It may say odourless in the directions. Who knows
21st April 2013, 09:15 AM
Hi there
I used automotive sikaflex, you can get it from bunnings it is safe for sensors, from memory it is black "tube" has a pic or a red car on it. Not cheap but good stuff.
TapTap Makatini
21st April 2013, 10:14 AM
A lot of them will say if they are sensor safe.
Hello from Under Down Under!
21st April 2013, 08:09 PM
Hi. I use to use sikaflex years ago to reattach the lower sill trims to my vnss i forgot all about that stuff. Yep its costly but it works gr8
Thanks for the memory recall
The Following User Says Thank You to jgoose For This Useful Post:
21st April 2013, 09:55 PM
#8
Hardcore
Yes Sikaflex is the go , or soudal T-rex is what i just used for my snorkel
22nd April 2013, 12:18 AM
#9
Just read the label it will clearly state if its sensor safe and will be reflected in the price tag
If this is the stuff your referring to it hasn’t got it written on it that its sensor safe from memory so its up to you.. http://www.supercheapauto.com.au/onl...id=11079#Cross
When I refit mine as I didn’t trust Nissan to seal it up correctly i used this stuff http://www.supercheapauto.com.au/onl...om=51001#Cross
22nd April 2013, 09:43 AM
#10
Hardcore
The Sikaflex 227 is Sensor safe, just to confirm, i had it sealing my Snorkel for over 12 months it works well.
The Sikaflex creates a stronger joint/bond than the ultra blue, i prefer a strong glue for sealing a snorkel, the ultra blue is good for gaskets etc, but sika is good for sticking stuff together you dont want to come apart !
