Results 11 to 20 of 21
Thread: Squeaky door!
    Jul 2012
    Mine squeaks too specially when driving under the rain. I think it is the weatherstrip that is rubbed with the body that produces the annoying sound.
    Advanced boosh's Avatar
    Auburn, SA
    Quote Originally Posted by GUtsy ute View Post
    Hey Biggus, Try using heatshrink on the locking bar, it lasts for ages.
    I got a heatshrink from etsa. The bloke just handed me a peice, didn't have to pay for it
    The heatshrinks from etsa actually have adhesive in them so even if you have to cut it to get it on there, it'll stick to itself and not shrink away from itself... Works a charm!
  4. #13
    Alex, I have the same issue with mine. Do u have any hints for a resolution or are you just grinning and bearing it?
  5. #14
    Jul 2012
    Quote Originally Posted by Jamesandlizk View Post
    sorry i failed to read this tread again I didn't know you posted a Q on my post. The squeaking was solved by the shrinkable tubes but I removed it lately due to door open light warning. It didn't solved the door light issue so i'll stick some shrinks again, maybe thinner this time.
  6. #15
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    So does the heat shrink help with that noise when you open or close the barn door coz lube didn't help it?
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
  7. #16
    Patrol Guru
    NT
    You aren't by any chance suffering from a broken spot weld (usually a crunch when it shuts) this will need some holes and bolts like this :
    You can also see the lithium grease on the dampening arm. It wouldn't hurt to give the locking arm below a hit with the grease too as pictured here:
    Also the other end of it.
  8. #17
    Yea, Victoria
    Quote Originally Posted by gec View Post
    This may be a silly question, but how do you get the heat shrink on there, some pics would be great.
    Good question. My GU8 does the exact same thing, as did my GU2....
  9. #18
    Jul 2012
    Quote Originally Posted by Drew View Post
    not exactly the same case, the barn door squeaks only when the truck is running and it rains. the shrink holds the catch tighter. the shrink placed in there wouldn't at all help n the open-close door noise situation. hinges are to be blamed. hope i'm right.
  10. #19
    Are the hinges worn, can you lift the door up and feel any play.
    Might be as easy as drilling old hinge pin and e=inserting a bigger one..
    Keep the dry grease up to it in you maintenance routine,
    Hot soapy water to clean all rubbers then Tyre shine all your door rubbers inside and outside.
  11. #20
    Auburn, SA
    Quote Originally Posted by alexx View Post
    When I put the heatshrink on mine the light was coming on too. Easy fix for that is just to unscrew the button and put a washer or 2 underneath it. You only need to gain a couple of mm for it to work properly.
