Results 1 to 10 of 19
Thread: Custom Snorkel setups
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Id like to start a thread where people can post pictures of their custom snorkel setups to help out others that are planning to do the same.
    Here are a few pictures of mine and a mates.
    Please feel free to upload any pictures you have of your custom snorkel setup, especially if it is out of the ordinary.
    Here is a detailed DIY thread on making a custom stainless steel 4" snorkel for a TD42. Compiled by our very own AB.... http://www.nissanpatrol.com.au/forum...-steel-snorkel
    Hello from Under Down Under!
    Aug 2011
    North West Tas
    56 Post(s)
    Heres mine:
    (note the flexi pipe outside the engine bay was fitted by the previous owner and is long gone...)
    The cylinder filter is off a gutlux (yes it hurts to say it!). The elbow on it was cut off, rotated and braised back on to suit the engine bay.
    I only had to make the hole a little bigger so i just snipped with tin snips and folded over the edge
    Tough as stainless steel brackets from a truck shop
    I used door trim off an old car to go around the hole.
    This is the only way i could figure out how to join the flexi pipe to the rubber elbow
    Nice 3" stainless pipe
    Good quality fittings
    Finished product. Im still not sure how much water gets in the end when its raining, especially when when parked on a bit of a hill, but ive checked plenty of times and ive never found any decent amount of water in the filter...
    Also note that i have spun the hose clamps around so that the nut is pointing down and hidden from view now.
  4. The Following 3 Users Say Thank You to taslucas For This Useful Post:
    BigRAWesty (20th March 2013), blocko05 (2nd August 2015), MC97GQ (20th March 2013)
    Aug 2011
    North West Tas
    56 Post(s)
    Heres a mates.
    He got rid of the LPG setup and wanted to use the original airbox and filter. The idea was to run steel over the hot side of the engine so that the heat wouldnt affect the flexi pipe etc. The work was done by the local plumbing shop from his design. To save money he just got them to spot weld instead of seam weld and then just ran some sickaflex around the joins.
    The old square to round conundrum
    Pretty good workmanship
  6. The Following 2 Users Say Thank You to taslucas For This Useful Post:
  7. #4
    Dec 2012
    Picton
    Have you got any closer shots of what you did on top of the carby ? Or can you describe what you did ? Looks good tho that's what I've been looking for cheers
  8. #5
    Just putting this out there but is there any kind of formula to work all this out or is it just extend it??????????
    As Too long may not be ideal, Just asking.??
  9. #6
    Aug 2011
    North West Tas
    56 Post(s)
    Re: Custom Snorkel setups
    Quote Originally Posted by Matty13 View Post
    Here you go, This was on the car when I got so I don't know what it's been made out of.
    Note the gas fitting.
  10. #7
    Aug 2011
    North West Tas
    56 Post(s)
    A few more:
  11. #8
    Jan 2014
    Queanbeyan NSW
    Has anyone done a stainless install on the RB30? If so, Pics and tips would be great
  12. #9
    Legendary Alitis007's Avatar
    15 Post(s)
  13. The Following User Says Thank You to Alitis007 For This Useful Post:
  14. #10
    Jul 2014
    hi
    could someone with a y60 2.8 diesel post a buildingplan for a snorkrel if there are 2.8 diesel owners with snorkels.
