16th March 2013, 07:53 AM
Gasmaster Butane Double Burner BBQ
Just saw this double butane cooker for 60 bux on catchoftheday and ordered one seeing how I missed out on that other one similar to this, bugga, forgot the name of da udder one
The Following User Says Thank You to wolften For This Useful Post:
krbrooking (16th March 2013)
16th March 2013 07:53 AM
16th March 2013, 07:59 AM
I just upgraded to a gas (LPG) double burner. $50 from BCF, but you do need to buy a gas bottle too, I already had a 2kg bottle. I found those butane ones chew through the canisters way too fast.
16th March 2013, 08:03 AM
Moderator
Rays Outdoors now sell them for $34.95 but they don't come in a blow mould case (which is huge) normal price is $50 rrp. BCF will have the same thing.
Check out my Toy -->
Rogue Dung Beetle
16th March 2013, 08:05 AM
Moderator
I have the COTD one for about 18 months and its great but Rays have it all sorted now. The Blowmould case is massive!
Rogue Dung Beetle
16th March 2013, 09:50 AM
Travelling Podologist
I know that plenty of folks have used those butane stoves for ages without problem.......... But........ During our travels around Oz I heard of several first hand instances where folks had been using them & they blew up, luckily with only minor injuries, singed hair & the like. One person had their vehicle saved by a quick thinking neighbours with a fire extinguisher. The main problem is that folk tend to put to large pots or frypans onto them, which partially sit over the top of the canister compartment.
However I removed the one I had fitted to an external drop down door on the side of our bus after the seal between the canister & the stove became leaky. First I knew was when I lit the stove the flames weren't where they were supposed to be. I reckon I was pretty lucky it wasn't worse.
I had a heap of (brand name) canisters left over, & more recently bought a blowtorch attachment for them to solder up some Andersen plugs. New canister worked just fine for the first few I did, but then started leaking. I could see the vapour escaping. If I hadn't been on the ball it could have been pretty nasty.
As a result I've now given up on any appliances which use those canisters, I just don't trust them any more. When using yours please don't get complacent with them. Check EVERY time you use them to ensure you have no leaks.
Cuppa
The Following 3 Users Say Thank You to Cuppa For This Useful Post:
NP99 (16th March 2013), Stropp (16th March 2013), TPC (16th March 2013)
16th March 2013, 10:40 AM
Cuppa
Cuppa
Good advice mate, plus I'm sure all those canasters are coming out of the same factory in South Korea.
16th March 2013, 10:46 AM
The Mad Ozzy
I have the original U-Bute twin burner with hot plate and have never had an issue, also don't put over-size pots etc on it either. The blow mold case is very large and does take up quite a bit of room but still worth using it
www.swat4x4.com
16th March 2013, 10:55 AM
Hardcore
Cuppa
Cuppa
So are you saying that the hot gas is then forced over the canister ,and heats it up till it explodes ?
16th March 2013, 11:32 AM
...some good info there.
'Spose one should always check and tighten the canister before use.
16th March 2013, 12:34 PM
04OFF
Yup, if oversize pots & pans are used, which although obvious when mentioned, is something that is not uncommonly done.
